HYBRID Drag Gen 3 Kit
HYBRID DRAG GEN 3 TURBO KIT
DRAG Generation 3 Kits consist of these HIGH QUALITY parts:
Turbonetics TO4E Turbocharger
DRAG 4 into 1 Cast Iron Turbo Exhaust Manifold
TIAL Wastegate
DRAG Front Mount Intercooler (Polished Cast Aluminum End Tanks) Bigger Diameter End Tanks
CHOICE OF BLITZ,HKS,OR GREDDY Blow of valves
DRAG Mandrel-Bent Chrome-Plated Piping 2 1/4 IN/ 2 1/2 OUT CHARGE PIPE
DRAG 2.5" Exhaust Down Pipe
DRAG Wastegate Dump Tube
DRAG Blue Silicone Couplers and Clamps
MSD Fuel Pump
DRAG Vortech Boost Dependent FMU
DRAG Intake Air Filter Assembly
Map Sensor Bypass Valves
Stainless Steel Braided Oil Feed Line w/ Fittings
Oil Return Line Assembly
All Necessary Hardware and Fittings
All Necessary Hoses and Hose Clamps
All Necessary Gaskets
7 Series Cold Plugs
Here are some 1/4 mile times that where hit on this Hybrid kit
LsVtec 95 integ 15psi 11.8 122mph
B20Vtec 95 integ 08psi 12.3 118mph
LsVtec 93 integ 18psi 11.1 128mph
Gsr 4 dr integ 16psi 12.2 118mph
Cars where COMPLETELY stock besides the modifications listed below
*310 Rc injectors
*Block guard
*Copper sprayed head gasket
*Clutch
Will Sacrifice this Brand New kit for $3200
Please Email me with any questions you might have
ProjectSpeed@aol.com
Thanks
TIAL Wastegate
MSD Fuel Pump
7 Series Cold Plugs
*310 Rc injectors
*Block guard
*Clutch
Thanks
