GSR trans locked out of 1st and second gear
I had to swap the case of my GSR trans because the threads blew out of the case for the passenger mount. Swapped everything over and put it back into the car yet I cannot get the car into 1st and second gear, it will go into every other gear no problem. Any idea what could be causing this? Transmission never had any issues prior to this
It's wise to test whether all gears work prior to reinstalling the housing.
You probably need to disassemble and check your work.
turbo-2nr
Transmission & Drivetrain
Nov 29, 2012 09:05 PM
