ARP Rod Bolt Question?
Old Jan 7, 2020 | 08:10 PM
Munafo24's Avatar
Default ARP Rod Bolt Question?
I bought a set of arp rod bolts for my b16 crower h-beam rods not knowing they need to be pressed in by a machine shop. Im looking for a bolt that can simple screw right into the rod like the stock bolts. Does anybody know if arp makes a bolt style rod bolt instead of the stud and nut that i have? Im on a budget so im looking for a cheap and easy solution. If it comes down to it i will just get the machine work done but i would like to avoid it if possible. Any info would help.
Old Jan 7, 2020 | 08:49 PM
JKaze's Avatar
10 Year Member
Default Re: ARP Rod Bolt Question?
Rod bolt type depends which type the connection rod uses. So if your Crowers really uses OE stud-type rod bolts and you want screw-in type bolts, sell them and purchace different set. OEM-rod uses press-in studd and ARP sell replacement for that.
Most aftermarket rods uses basic screw type, main differences in diameter ,UHL (=under head lenght) and hardness, and ARP usually had made of them.
Bolt type changing is possible in theory but highly uneconomical because machining cost.
Old Jan 7, 2020 | 09:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
What's wrong with the Crower bolts ? Based on what you have described, you bought a set of factory rod replacement bolts and NOT a set of aftermarket rod replacement bolts. If you have a set of Crower "Fast Times" rods, you likely have a set of 5/16" x 1.50" length rod bolts with a 3/8" 12-pt head. In that case, the ARP2000 replacement bolt set part number is: 200-6210.
Old Jan 8, 2020 | 06:59 AM
Munafo24's Avatar
i bought these rods off a friend of mine a while back so if this is the 3rd build they are going to be used in. Im just not too sure how well the bolts will hold up after being torqued so many times.
Old Jan 8, 2020 | 10:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Agreed. Get a new set.
Jordb22
Jan 31, 2012 08:37 PM
Tony the Tiger
Aug 30, 2008 12:55 AM
visionsOFmadness
Dec 28, 2005 03:22 PM
BoostedCivicSedan
Feb 17, 2005 05:56 PM
GOLDBERG
Sep 5, 2003 03:04 AM
