Type r knucleson my EG
32mm hubs should work fine (all usdm 94-01 integra use the same knuckle 51210-SR3-N10, and i know people running ls/gsr with their d) however jdm 36mm hubs wont work.
Never done it with a D axle, but as long as the shafts are the same diameter and the spline count is the same (I believe they are), it will work fine. You just knock the old joint off, slide a new boot on, and tap the new outer joint on. I've been using this method for twenty years to replace outer boots without taking the whole F'ing axle apart. You can pick up new outer joints on eBay for like $30 as I remember.
Idk about his setup, but I do know that GSR axle outer ends work in civic hubs. We need to know what the knuckles came from to determine what hubs they have in order to verify whether the axles fit, like others have said.
SpoogenJay
Suspension & Brakes
May 26, 2005 08:14 AM
