Intro - 1994 DC2 VTiR
Hi All,
Just introducing the new project track car, this 1994 Integra DC2 VTiR.
Picked it up December 2019 with 270,000 kms and a couple of mods on it
The current build cost is:
- JDM Front conversion
- Carbon Fibre/Fibreglass hood
- Fibreglass front
- Metal front guards
- Bride Low Max bucket seats (claimed to be original)
- CE28 Replica wheels
- Swapped another B18C2 at 180k kms
- Front Crash Bar
- Working rear shocks
- Stock seats (Bride's aren't ADR compliant)
- Rear Trailing Arm bushing replaced
- Oil leak fixed up (Suspect a cylinder head seal)
- Indicator lights (Bulbs and fuses look fine, think it's a burnt ICU)
- $250 Front Crash Bar
- $24 Spark Plugs (BKR6E-N-11)
- $35 Castrol Edge (5w30)
- $10 Oil Filter (Wesfil Z79A)
- $20 Rear shocks
- $266 Front brake rotors (DBA T3 4000 series)
- $83 Rear brake rotors (DBA Street standard)
- $60 Rear brake pads (Pmu ns400)
- $80 Front Seats (gsi)
- $40 ICU (gsi)
- $5 Front Impact bar bolts
- $20 Rear camber arms (ebay spec)
- $142 Rear Trailing Arm Bushing (Hardrace)
- $18 Wipers (Youen - AliExpress)
Issue: Rear drivers side indicator light not working in dc2 vtir.
After checking the fuses and bulbs which both looked fine, this ICU (Integrated Control Unit) was the next suspect.
Upon more testing, the hazard lights stopped working as well and then I came across this post.
This is the printed circuirt board of the ICU out of a dc4 gsi, looks pretty much the same. Someone was requesting it in another thread for a picture to recreate it, but I haven't met the post count yet to reply to it.
Back PCB
Front Resistors
ICU With Cover
A number of things
It controls the output of the drivers door pin switch, turn on dome light, turn on a warning chime, [if needed].
It has the rear window defogger timer in it.
It controls windshield wiper intermitent and park functions, along with other things.
A symptom of a defective ICU, [a common Honda/Acura problem] is one or more of the above not working.
What exactly is your problem? 94
Back PCB
Front Resistors
ICU With Cover
Just so you're aware, here's the definition of the term "boi": https://en.wikipedia.org/wiki/Boi_(slang)
- got a type-o on there...
mdb4879
67
Jun 22, 2015 05:34 AM
court76wi
48
Jun 28, 2007 09:29 PM
TodaSi
Aug 20, 2002 04:20 PM
