Top End Rebuild?
Near end of last season we noticed a small bit of oil pooling in the garage under the Ruckus.
Long story short, I believe I've blown a piston gasket as a result of going downhill faster than the engine braking, causing blowback through the breather hose that isn't run into any sort of catch can due to a custom air filter.
Not having explored this kind of work before, I'm uncertain what exactly I need to order in order to rebuild the top end of the engine. A Google search resulted in some top-end kits from various websites, but prices vary and I don't really know what all I need...
Is it as simple as a new piston, gaskets, and seals? Is there a kit I can buy for a 2012? What do I need to know before ordering parts, other than year make and model?
Thanks in advance for all of everyone's help!
If you are going into a head build I would also look into replacing your valves. From what I have seen and read, it's not nearly as complicated as a car motor, but you do need to make sure you have all the gaskets needed. I'm going to be doing a valve adjustment soon on my bike and plan on inspecting the rest of the head while I'm doing it. What parts are you looking into?
akstunt600
Honda Motorcycles
Jun 25, 2006 11:32 AM
Simon Tibbett
16
Dec 24, 2003 07:27 PM
