Feedback and questions on suspension for circuit/street dual duty
Hello i have 96 civic ej9 that im going for a track car that will be also used as a daily.. i got the tein flex z coilovers enregy suspension bushings got the bigger brakes from a 94 ex and stainless steel stoptech brake lines and a oem 22 mm front sway bar what else should i get not going full race car im on a budget because i want a b series swap.. so i need a rear disk conversion a rear sway bar and a rear subframe brace and what about the skunk 2 pro series front upper control arms are they good or i can just keep the oem UCA and replace its bushings with the energy suspension ones? Same with the lower arms front and rear. Any advice/suggestions will be helpful
What's your experience level like? If you're just starting on on going to the track, spend that money on track time instead of parts.
well where i live track time is very expensive and there are only a few tracks the closest one to me is 3 hour drive so if im about to start going to the track i want to come with my car when its built for it
I'm going to parrot the posts above.
What's your experience level when it comes to tracking a car?
If you have a budget and it sounds like you have almost no budget why would you wait to track the car then?
Take it out bone stock and learn to drive it as is.
Most of us know people who have the ability to drive bone stock cars and pass everything on track. Even superior horsepowered cars.
Its not about how fast the car can go, its how fast you can drive the car.
Also if you cant afford to go to the track then do some solo events instead.
News flash.... most tracks around me are 3 hours away except one Laguna Seca is 40 mins from me
so you have to ask yourself. how bad do you want to drive on track?
You can track and not have a race car.
Not all go fast parts help you either.
so you have to ask yourself. how bad do you want to drive on track?You can track and not have a race car.
x5 or 6 or whatever. You're getting experienced opinions from people who track regularly. All you really need are safe brakes and clean/new fluids. You truly dont need anything else provided your tires aren't so old they're rotting.
I meant as in something with some heat cycles left in them regardless of type/tw etc.Last edited by Dublocivic; Jan 7, 2020 at 09:17 AM.
send it... as long as you have a reliable car with good brake fluid and "maybe" upgraded brake pads you can learn a ton.
the object is to learn skills, the line, and car control... go fast parts wont make you faster (i'm a shining example).
Rear disk conversion is nice, but not completely necessary for now. These cars have very little weight in the rear and most run a much more aggressive pad in the front than the rear to keep it from locking up.
A rear sway bar isn't necessary either, but it will make the car more fun on track since it will push less and rotate better.
mightnightrunner
Mar 27, 2009 05:26 PM
