Forged Higher Comp Pistons and Stock ECU. Is it possible to use?
Old Jan 5, 2020 | 05:12 PM
F3L0N's Avatar
Default Forged Higher Comp Pistons and Stock ECU. Is it possible to use?
Hey guys, would a B18B1 stock ECU adjust for forged 9:4 compression pistons. The stock compression on a B18B1 is 9:2. I assume the ratio change is negligible also considering the stock pistons had built up carbon adding to compression anyway. I thought i'd ask some pro's on here before I start the car, run lean and hate myself. I am trying to avoid a tune and drive the car for a bit.
Old Jan 5, 2020 | 09:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: Forged Higher Comp Pistons and Stock ECU. Is it possible to use?
No, the stock ECU cannot adjust for increased compression. Idle and light part throttle operation will likely be ok to drive and the stock ECU closed loop operation will add fuel to compensate enough to keep the engine out of danger, but it cannot alter the fuel and ignition maps for full throttle operation.
So, take it real easy until you can get it tuned.
Old Jan 6, 2020 | 06:25 AM
F3L0N's Avatar
Thanks JRCivic1, In that case I'll probably only start it and let it idle for a bit to somewhat break in the piston rings.
VVENOM800TT
Feb 17, 2011 02:48 PM
Paegelow
12
May 29, 2010 07:32 PM
hondacura22
Mar 25, 2009 06:07 PM
Tippyman
May 4, 2008 08:43 PM
mugenhatchie
Mar 27, 2005 08:35 PM
