Blow Off Valve: Do the flange type and location of the valve matter
So every time I post now I feel a bit dumber lol. Its been a while since I've modified things and I figured I'd double check before venturing forth.
I have an EK hatch with a boosted B18 in it, car came with a TurboXS Blow Off Valve installed on the piping. If I wanted to switch it out for something like an HKS Super Sequential, would the mounting point be the same ? Any issues that could arise from switching brands/models as far as it not being "plug and play" ?
Thanks in advance
Thanks in advance
the welding flanges may be different. the ones from Turbosmart & TiAL are the same. The HKS is unique to that company, and although GReddy has some 3rd party makers of their flange, it is not as wide as the genuin6article from GReddy.
As for location, they're typically to stay in the same location.
Couple boosted B-series guys out my way have it like this. Come to think of it, they are also closer to my age as well, being in their late 30's. Lol! I'd guess it died down due to costs. Folks got cheap and modifying an end tank for a BOV either meant an unnecessary spend, or larger spend on a custom front mount.
From what I recall, the theory for that location was to minimize turbo surge. I don't think anyone was able to really prove it was better than the typical FMIC piping before the throttle body.
Swapping from a TXS to an HKS would be a flange change typically, as they are definitely different flanges (if you have the "univesal" TXS RFL"). The 2 could be adapted via coupler, but the ideal solution would be to cut/replace flanges to fit the appropriate valve direct to the pipe.
TS 50mm and Tial 50mm are actually different flanges. TS makes a version of their BOV to fit the standard Tial flange, but the Tial 50mm does not seat on the TS flange..more confusing than it needs to be. Looking at them separately it would be unnoticeable; but the outer lip/o ring seating is definitely different.
So my apologies for my perspective.
Just trying to clarify for those that may get confused as it can be confusing.
TS has 2 flange part #s for the 50mm Raceport (one for the TS specific flange, and one for Tial flange fitment).
TurboEKcoupe
10
Dec 17, 2005 08:16 AM
