cruise control not working
Old Dec 29, 2019 | 03:41 AM
youstolemybeer's Avatar
5 Year Member
Default cruise control not working
Hey folks, I have a 1995 civic lx that the cruise control is not working. The light come on when the button is pressed and that's about it. Ive held the set button for random times (5seconds,10,15,20) thinking that the electric motor has to take up slack. Nope. it didn't move. where do I start diagnosing this the car/engine has 397thousand on it so Im not that worried about it, but would like to fix it for giggles
thanks
Old Dec 29, 2019 | 07:56 AM
mk378's Avatar
Default Re: cruise control not working
Are you talking about the light in the "cruise" button on the dash or the green "CRUISE CONTROL" light in the bottom right corner of the cluster?
The button on the dash enables the rest of the system, and its light only means that the button is in the down position (this is a click once for on, click again for off mechanical latching button). More interesting is when you press the SET button on the wheel, the green CRUISE CONTROL light in the cluster should come on. This requires three things:
* Road speed 35 mph or higher.
* Brake pedal is not pressed.
* If manual, clutch pedal is not pressed.
There is a switch on the clutch pedal whos only function is to drop out the cruise. It has the same kind of breakable plastic pad as the starter interlock switch and the brake switch.
The buttons on the wheel go through the clock spring. Especially if you're also having trouble with the horn or the SRS the clock spring could be broken.
Old Dec 29, 2019 | 08:45 AM
5 Year Member
thanks, it turned out that the rubber pad on the clutch pedal was not there, I shoved so wire in the hole and yahooeeee the cruise now works. thanks again
Old Dec 29, 2019 | 11:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
So order a new rubber pad and fix it right... get rid of the wire.
Old Dec 30, 2019 | 01:44 AM
5 Year Member
its on order, should be here friday
cloud2kz
Aug 26, 2009 11:13 AM
RyanPm
Jun 20, 2009 05:28 AM
Elvis1977
Jan 13, 2004 10:52 AM
Johnytang
Mar 12, 2003 08:48 AM
HuskerHybrid
Jan 16, 2003 04:58 PM
