1999 Accord rear rotor removal question
Old Dec 28, 2019 | 01:52 PM
Fiercesomest's Avatar
Default 1999 Accord rear rotor removal question
Hey all,
Trying to get my rear rotor off for an overdue replacement, but it appears to be a single piece (pictured below). Will I be sad if I go at it with a hammer?
Old Dec 28, 2019 | 05:55 PM
angrysmileyface's Avatar
Default Re: 1999 Accord rear rotor removal question
The holes should be threaded. If everything is backed off or removed properly all you should need is a hand full of bolts and then they can be used to push the rotor off
Old Dec 29, 2019 | 05:11 AM
Fitz Williams's Avatar
10 Year Member
A little penetrating oil between the hub and rotor might help also.
Old Dec 29, 2019 | 06:04 AM
Awesome. So I'm hearing that I can take a hammer to it, no sweat. Should knock it loose, yeah?
Old Dec 29, 2019 | 01:55 PM
MAD_MIKE's Avatar
MM Gruppe B
I wouldn't beat on it too much. Bearings don't like that.
The original rotor screws can be used two fold.
One to attach the rotor, the other is to move the screws to the threaded rotor holes from the countersunk holes to aid in pushing the rotor off the hub.
But from the looks of it, those screws are long gone.
Get some grade 8.8 or better bolts, anti-seize, mini map gas torch.
Slather the bolts in anti-seize, screw them into the non countersunk holes and apply a bit of pressure evenly to both bolts.
Start applying heat to the rotor evenly while adding pressure with the bolts.
Make sure the rust around the register bore doesn't interfere with removing the rotor.
If all goes well the heat and pressure should allow the rotor to come off the hub.
When you get the rotor off, make sure to apply some anti-seize to the back of the new rotor hub so it won't stick next time. Not too much, just enough to be 'painted'.
Old Dec 30, 2019 | 04:33 AM
Mad Mike, thanks for the detail! I'll see if I can grab a couple bolts that will fit the threads, and I'll plan to only hit the rotor a little. Great idea with the antiseize too!
Ching Mendoza
Oct 27, 2017 11:42 PM
hb_guy
Mar 3, 2007 06:50 AM
SpeedracerS4
Aug 17, 2003 11:43 PM
