RPM's not working after new Dizzy 99 ej6 b18cr
Firstly, I know there have been several posts on this topic from years ago but i haven't found one yet with an actual resolution. Im really hoping to get this fixed as soon as possible.
Anybody have any idea why the RPMs have stopped working after installing a new distributor? The plugs match and connect blue wire to blue wire (rpm signal). Everything was working fine before the previous dizzy stopped working.
Tried 2 different brand new dizzys, still no rpms. Also took a multimeter to the blue wires and they are getting signal.
Motor: 98+ spec B18CR (JDM)
Chassis: 99 EJ6 (EK)
Gauges: S2000 ap1 cluster w/ speedo healer
Not completely sure on the ECU (fairly certain it's obd2a)..i'll confirm and get back with that info.
Again, thanks for your help!
Verified w a multimeter from the harness plug that was connected to the dizzy plug that signal was coming through. Also tried jumping the wire from the dizzy side to the blue wire near the firewall at top right of the engine bay with no success.
96-98 b18 is obd2a i believe, so im only assuming that its obd2a based on that. I will confirm tomorrow to back that assumption up.
I'm going to try to jump from the Yellow and Green wire to the blue wire at the firewall when I get home from work and hopefully something good happens.
This^ seems like a risky location to obtain the rpm signal because the Yel/Grn wire sends the ECU spark signal to the distributor ICM. Ask the previous owner why he did not instead use the blue rpm wire from the distributor ICM for the tach signal. Connecting the blue distributor wire to the tachometer would be the best way to go.
...the car is still wired as it was stock but is using an ecu adapter for the ECU from obd2b to obd2a. He said that the harness doesn't even have the blue wire at all and that the car gets the signal from a Yellow and Green wire from the distributor and that does the same thing as the blue wire.
btw, this guy never owned the car, he is just the person that did the swap.
Actually, the car does have a stock blue rpm wire but it runs from an ECU connector to the cluster. I suspect that the previous owner tapped into this blue wire to get the rpm signal to the S2000 cluster. Alternatively, he ran an entirely new wire from the distributor to the S2000 cluster through the firewall.
I also saw that the original dizzy was stamped TD-87U and the new one is TD-84U. Do these differ by obd2a or obd2b in anyway?
I have tried jumping the blue dizzy wire directly to the light blue wire on the shock tower and still got no results.
He is telling me that the yellow and green wire sends the rpm signal from the igniter, this is why I thought I might try jumping it.
My recommended fix --> Run a new wire from the distributor blue tach wire through the firewall to the cluster.
Light blue wire at shock tower i jumped to.
New TD-84u dizzy connector.
Old TD-87u connector.
New dizzy wires.
Old dizzy wires
First pic:
If the blue wire in this pic is attached to a nearby 2P connector (tachometer test connector), then it should have continuity with the blue wire attached to the cluster tachometer. If so, this means you should be able to get the cluster tach working again by running a new wire from the blue distributor wire to the blue wire attached to the tachometer test connector.
First pic:
after further testing, multimeter is getting readings to the test plug and readings from the actual wire in C5 in back of the cluster but still showing no rpms on the cluster. Jumping from dizzy blue to tester also did nothing..im so lost. Could be the cluster is bad. Testing a different one as we speak
