Can I leave the jammed woodruff key in place or do I need to remove it?
Old Dec 28, 2019 | 10:20 AM
philztheone's Avatar
Default Can I leave the jammed woodruff key in place or do I need to remove it?
My woodruff key is jammed into place (see photo), can I leave it as is(It took some doing to finally pry the crankshaft off.)? Do I need to remove this key(Had a go at it with a needle-nose pliers which didn't work.)?
Don't know if this relevant but it's a 1997 Accord DX straight stock as far as I know. It has an F22B2 engine. 2.2L, SOHC.
Thank you.
Old Dec 28, 2019 | 02:52 PM
Default Re: Can I leave the jammed woodruff key in place or do I need to remove it?
I'm leaving it in place. Started to file the key and got the pulley to be flush with the crank. I wanted to replace the crank seal but I will replace all else and hope the seal gods are with me.
Old Jan 23, 2020 | 09:49 AM
416Gang's Avatar
So you filed the key down? When it comes to reinstall the pulley, how do you know if its going to line up with the key, if its filed flush to the crank?
Old Jan 23, 2020 | 04:39 PM
NVturbo's Avatar
O.G. triple O.G.
You should NEVER have to do anything to the woodruff key besides installing it into the groove. It's that shape and form for a REASON.
Old Jan 23, 2020 | 11:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It shouldn't be filed down flush with the end of the crankshaft... it sticks out on purpose so that more surface area contacts the crank pulley. It doesn't stick out past the face of the crank pulley when correctly installed, so you wouldn't have to worry about the crank pulley bolt contacting the woodruff key before it is properly torqued.
karrar55
Mar 26, 2011 08:40 AM
949
Southern California
Oct 26, 2009 09:14 PM
h22a41997
Nov 15, 2006 02:14 AM
friscorice88
Dec 13, 2005 08:40 PM
Honda_18
25
Dec 5, 2004 02:38 PM
