Odyssey stuck brake - not caliper?
1997 Honda Odyssey - Cleaned up caliper assembly, replaced piston and seals. Piston keeps sticking out. Brake line seems fine, i.e. have plenty of fluid during bleed. Pins are cleaned and lubed. Blew ports out on bolt holding line to caliper. Stuck on the road 1400 miles from home. Any help is appreciated.
Good find!
The rubber hose will likely return to shape under pressure, but I would still recommend to replace it with brand new because at this age it had already stretched, and now this deformation is not adding any confidence.
Roger that. Going to wait until I'm home in case I have to replace any steel line or cut & flare, Fitting is WI rusty. Keeping an eye on it. Caliper acting fine for now. 240K and cancer ridden, trying to keep her alive a while longer. Vandwelling in NM at the moment. Thanks for the response.
dgdarien
Sep 15, 2009 04:23 PM
