Turbo oil feed location. Can I use the VTEC solenoid location?
Old Dec 27, 2019 | 01:13 AM
thugsbryan's Avatar
Default Turbo oil feed location. Can I use the VTEC solenoid location?
Guys just want to know if it's ok to take my oil feed for the turbo from this oil port at the front
Old Dec 27, 2019 | 02:49 AM
NVturbo's Avatar
O.G. triple O.G.
Default re: Turbo oil feed location. Can I use the VTEC solenoid location?
I would use an adapter fitting at the stock oil pressure sensor. That location at the cam seal may not provide enough oil for the turbo
Old Dec 27, 2019 | 03:49 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I would be concerned using that port since it’s at the vtec solenoid, I always use the oil pressure sensor port
Old Dec 27, 2019 | 06:51 AM
NVturbo's Avatar
O.G. triple O.G.
I personally know someone who used that same port by the VS....and destroyed 2 brand new turbos before he realized that was the issue. I mentioned that he needed to re-route it to the oil pressure sensor but he didn't "feel like it". lol
Old Dec 27, 2019 | 10:48 AM
Txdragon's Avatar
Oh nice! He felt a bit more compelled after killing the 2nd snail?
Old Dec 28, 2019 | 11:55 AM
civic-steve-94's Avatar
If you use the golden eagle mfg oil filter plate it sends filtered oil to the turbo.
Old Dec 28, 2019 | 12:03 PM
thugsbryan's Avatar
I have it there for a while now but was jus wondering if it 2will cause any problems, have a few frens that run there oil feed from there also
Old Dec 28, 2019 | 12:19 PM
Balor_Gr's Avatar
I used this point. 2-3 years and around 15.000 kms maybe more no oil problem on a TD05.
Old Dec 28, 2019 | 12:25 PM
thugsbryan's Avatar
Originally Posted by Balor_Gr
https://www.youtube.com/watch?v=P9CcNLSEN2w
This location wud give the same oil pressure as where I have mine wudnt it?
Old Dec 28, 2019 | 03:04 PM
Balor_Gr's Avatar
Pressure yes. Flow probably more.
Old Dec 29, 2019 | 02:33 AM
NVturbo's Avatar
O.G. triple O.G.
haha...yeah, I kept mentioning that the oil feed may be the culprit. Funny thing is that it was fine for the smaller Turbonetics turbo he originally had on there. Just enough oil droplets I guess to lubricate the CHRA.
He finally tested it by removing the oil feed line from the turbo and put the end fitting into a plastic container. Turned on the engine and barely enough oil was coming out of the line at idle. I'm assuming there will be oil there once the solenoid is activated......like 4000rpm+.
Old Dec 30, 2019 | 06:10 AM
Chance EG's Avatar
Default Re: Turbo oil feed location. Can I use the VTEC solenoid location?
What material/what is that intake elbow coming off the turbo? That looks like dryer duct lol....
Old Dec 30, 2019 | 06:14 AM
thugsbryan's Avatar
LOL, it's aluminum, i don't have it there anymore tho, it can expand an retract an bend to where u want to put it, but
Old Dec 30, 2019 | 08:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You cannot use the VTEC test port on the front of the cylinder head... almost no oil volume is found at this location UNTIL VTEC engages.
Old Dec 31, 2019 | 10:00 AM
NVturbo's Avatar
O.G. triple O.G.
B I N G O !!! People swear that location works but it doesn't.
Old Dec 31, 2019 | 10:18 AM
thugsbryan's Avatar
Oh boy, I guess I will Ave to relocate it to the back of the engine then
Old Jan 2, 2020 | 02:20 AM
NVturbo's Avatar
O.G. triple O.G.
You're making it harder than it really is. All you need is a longer 3AN oil feed line, plug for the VTEC solenoid tap and an adapter fitting for the rear......
Old Jan 2, 2020 | 06:08 AM
TheShodan's Avatar
Moderator
I think they only swear by it because either A) they never expected their turbo ro last that long anyway, or B) they didn't see their turbo smoke immediately from oil starvation, so it must be good!!
Old Jan 2, 2020 | 06:10 AM
thugsbryan's Avatar
To be honest I have had my oil feed at the vtec for over a year now on the same ebay turbo
Old Jan 2, 2020 | 06:15 AM
TheShodan's Avatar
Moderator
a year is peanuts. and i can only gather that because its an ebay turbo.. expectations can't be that high.
Old Jan 2, 2020 | 06:30 AM
thugsbryan's Avatar
ok I'm gonna run the line at the back and use a 2mm restrictor
Old Jan 2, 2020 | 07:07 AM
TheShodan's Avatar
Moderator
DO NOT put the restrictor at the back of the block. the fitting (not flange) need to be at the turbocharger inlet.
2mm is quite large and you may flood the system. what turbocharger specifically are you using again? what is your standard oil pressure?
Old Jan 2, 2020 | 07:10 AM
thugsbryan's Avatar
No I wudnt put the restrictor at the back of the block, it's a T3 t4 to4e turbo, maxspeedingrods brand, my oil psi is 60 on cold start 80 on Rev and 30 at warm idle, I thought journal bearing turbos used a. 065 restrictor
Old Jan 2, 2020 | 08:33 AM
NVturbo's Avatar
O.G. triple O.G.
Yeah I believe it was option B with my cousin's initial setup. Like I mentioned before, he insisted on keeping the oil feed there until it was too late and costly...
Old Jan 2, 2020 | 08:48 AM
TheShodan's Avatar
Moderator
You're correct. But the restrictor size is dependent upon the turbocharger manufacturer. So, a Maxspeedrods journal bearing may use something smaller or larger, hard to say. . But 2mm is not equivalent to .065". It's equivalent to .080", which is slightly larger. I honestly don't think that's a bad thing, because we don't know how well the tolerances of the thrust bearings and collar are.so, you're just going to have to try to see if that's the case. I'm quite sure Maxspeedrods won't tell you anything.
