Honda problem
Old Dec 23, 2019 | 04:28 PM
viola floria's Avatar
Default Honda problem
I got a 1988 crx with a d16z6 swap that will not rev past 2,000 rpms like it’s bouncing of the rev limiter and will not idle. I’m pretty clueless as to what it could be. Not sure if maybe they used the wrong ecm or if it could be a bigger problem. Any ideas?
Old Jan 7, 2020 | 08:43 PM
Efmysedan's Avatar
Default Re: Honda problem
Does your z6 have the vtech head?
Old Jan 10, 2020 | 09:52 AM
muellersfan's Avatar
A P07 ECU is definitely the wrong ECU for the D16Z6 engine, which should be run on a P28 ECU.
The P07 ECU is designed for the D15Z1 engine.
http://www.phearable.net/information...daeculist.html
momoxsparco558
Oct 11, 2009 03:55 PM
1988c-rex
Dec 8, 2005 11:10 AM
