Power Enterprise Timing Belts
Power Enterprise just recently put out some super strong timing belts for the H22A, so I thought I would come here for some feedback.
From what I have read, some say these are a MUST for Toda Spec B cams or above. From the specs that's 295 IN and 285 EX right?
Well I'm running Crower Stage 3 H22A cams, 297 IN and 295 EX!!
Is this a no brainer?
My follow up question regards the H22A auto-tensioner. H22's have a hydraulic tensioner that keeps retightening the timing belt. Do you think this would be bad for the Power Enterprise belt? Should I switch to an H23 manual tensioner if I was going to run this belt?
Thanks in advance!
Is this a no brainer? My follow up question regards the H22A auto-tensioner. H22's have a hydraulic tensioner that keeps retightening the timing belt. Do you think this would be bad for the Power Enterprise belt? Should I switch to an H23 manual tensioner if I was going to run this belt?
Thanks in advance!
Interesting, I didn't know that PE had released a timing belt for the H22, definitely something I'll look into if I ever get cams. I'm interested to see what people think regarding using this belt w/ the hydraulic tensioner. Any links where to buy? Also what do you guys think about using this belt on a stock motor?
I think most would say it's a waste on a stock motor.
I found out H22 belts were now made from H-T member Prospeed, he is selling them from his shop.
PE's H22 belt has been out for awhile, and i do carry those
Hey!!!
Well it's new to me! PM me a price if you want my business!
What about the autotensioner? I'm pretty much decided I should get a manual tensioner.
btrim23
Jun 2, 2004 08:24 PM
