1989 Civic CRX SI Yard Sale - $1250 - Los Angeles, CA
Old Dec 20, 2019 | 05:49 PM
Race_RPM's Avatar
Default 1989 Civic CRX SI Yard Sale - $1250 - Los Angeles, CA
TAKE IT ALL FOR $1250 $1000 as is, where-is, shipping extra, but pickup is free.
-or-
Make offers on specific items that make it worth the time to package and ship thing separately. As general guidance:
  • New parts: Send me your best price on a new part and you can have it for 33% discount + actual shipping (pickup is free)
  • Used parts: Send me a reasonable offer and its yours.
Parting out spares from a racing effort that mostly used original OEM components, but some fancy race stuff too. Easily worth $2000 even with new items priced at a 20% discount off eBay prices (incl. shipping, tax, etc.) and used, but usable items priced at a further (25%-95%) discount depending on condition. Availability of parts (and total pricing) subject to change -- I'll update both as parts sell.
Currently in L.A. / Manhattan Beach, CA: Take it all for $500
$20 D-series flywheel (1989 CRX pull; works fine)
$20 D-series clutch (stock, used, but ok)
$100 Head D16A6 PM3-17 (used; includes cams, valves, springs -- worked when removed; needs a gentle clean and oil, guaranteed "ok")
$100 Front bumper fascia (new in plastic) -- 1990-1991 (should fit 1988-89 as well)
$50 (1) Aftermarket Aluminum Radiator (#7322A -- new in box; fits all 1988-1991 Civics and CRXs, but overkill for HF)
$50 Axle left (66-4060) (1 new, inexpensive aftermarket - Autozone?)
$50 Axle right (1 new, inexpensive aftermarket - Autozone?)
$100 Axle right (DriveShaft Shop indestructible - 1 new)
$15 Lower right/passenger's rear A arm (1 OEM used steel)
$50 Right / passengers upright / knuckle (used; nearly new lower ball joint in perfect condition, but upright needs a new hub bearing)
$75 Front 4-lamp Rallycross light bar (Hella lights for night/rallycross racing) with spare bulbs (2 new B9005, 1 new B9006)
Currently in Richmond, VA: Take it all for $750
$2 Honda oil drain bolt (new) and (3) Oil plug washers
$30 ($10ea.) (3) new Oil filters - Mobil 1 - M1-104A
$5 CRX/Civic Hanes repair manual + CRX electrical diagram with clipboard
$1 spare light bulb for tail lights (1 new T2057)
$150 ($75ea.) Alternator (2 new rebuilts #14989)
$14 ($7ea.) Alternator Serpentine Belt (# 3PK0760, 30.66" Outside Length, 0.4" Top Width - 2 new)
$40 Rear wheel bearing and hub assembly (new Timken #513035)
$120 ($40ea.) Front wheel bearing (3 new Timken #513024)
$1 Axle oil seal - direct fit (Centric 417.61004)
$10 Spark plugs (4 used NGK #5632) + 3 mildly used -- all work 100%
$30 ($15/ea.) Lower ball joint - FA1479 (2 new)
$5 Spark Plug Wires (used 1 set, worked fine)
$Free brake line rigid (used)
$30 Beck Arnley clutch cable 093-0599 (1 new)
$30 ($15ea) Beck Arnley clutch cable (2 used; like new perfectly usable -- worried they were bad but realized the problem was a bent clutch pedal assy!)
$25 Brake Master Cylinder (new)
$5 Polyurethane steering rack bushings (used)
$25 Fuel pump and hose fitting (used, worked fine, stored in plastic ready to use; walbro PN = ?)
$25 FuelSafe fuel pump anti-slosh box with check valves (used, works fine, in plastic bag)
$70 ($10 ea. new, $5 ea. used) K&N style v-cone air filter (5 new + 4 used and need cleaning + fresh filter oil)
$35 Front Right caliper (new Centric 141.40043)
$125Front Left / Right pads (1 set new + 1 set used - verify part #'s, should be DTC-70's)
$35 Front Left caliper (new Centric 141.40044)
$5 Rear Right rotor (1 used but 100% usable, in box for Brembo 08.7104.14)
$50 Rear Right caliper (new Centric 141.40523 - stamping shows R)
$5 Rear Left rotor (1 used but 100% usable, in box for Brembo 08.7104.14)
$50 Rear Left caliper (new Centric 141.40524 - stamping shows L)
$80 Rear Left / Right brake pads (1 set new + 2 sets used - verify part #'s, should be DTC-60's)
$free OEM honda rubber brake lines (used, probably fine, stored out of sunlight for 10+ years - right front, right rear, left rear)
$10 (1) stainless steel brake line (new - left front)
$0 hardware for rear brake pad replacements (shims, bolts, brackets)
Last edited by Race_RPM; Feb 23, 2020 at 08:18 AM. Reason: sold a few things, found a few things, moved a few things, updated with per item sample prices
Old Feb 22, 2020 | 09:49 AM
Race_RPM's Avatar
Default Re: 1989 Civic CRX SI Yard Sale - $1250 - Los Angeles, CA
Ok - let's focus on a few big items for a special sale for the next 7 days (good until 2/29/2020). No junk!
$50 EACH picked up in Manhattan Beach, CA
(1) Front bumper fascia (new in plastic) -- 1990-1991 (should fit 1988-89 as well)
(1) Head D16A6 PM3-17 (used; includes cams, valves, springs -- worked when removed; needs a gentle clean and oil, guaranteed "ok")
$25 EACH picked up in Manhattan Beach, CA
(1) Axle left (66-4060) (1 new, inexpensive aftermarket - Autozone?)
(1) Axle right / passengers (1 new, inexpensive aftermarket - Autozone?)
(1) Right / passengers upright / knuckle (used; nearly new lower ball joint in perfect condition, but upright needs a new hub bearing)
$10 EACH picked up in Manhattan Beach, CA
(1) D-series flywheel (1989 CRX pull; works fine)
(1) Right rear lower A-arm (1989 CRX pull; works fine)
Xian
Jun 9, 2010 08:01 AM
4doorluv
Jul 30, 2009 05:00 AM
Aahj
May 1, 2009 12:59 AM
rcantu
Dec 28, 2006 08:53 AM
slacker~J
Nov 20, 2002 09:40 AM
