accord ex 95 vacuum
Old Dec 20, 2019 | 02:48 PM
dimfaux's Avatar
Default accord ex 95 vacuum
where do the vacuum lines go that come from behind the intake manifold (pipe#4) one goes to cruise control an the other?
File Type: pdf
Old Dec 20, 2019 | 05:06 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: accord ex 95 vacuum
Fairly sure that goes to vacuum hose #19. # 9 is resonator chamber Bs solenoid. #3 is resonator chamber B.
Old Dec 21, 2019 | 02:38 AM
dimfaux's Avatar
Thank you so much ive been looking everywhere for this diagram! So mine is missing hose#19+ everything thats after besides the resonator box(missing solenoids)will the car run with hose#19 plugged?
Old Dec 21, 2019 | 03:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Yeah, its a resonator for intake noise attenuation. Usually when a CAI or SRI in installed most of that stuff gets tossed. Although I thought the solenoid itself was left hooked up. But if you are not getting any weird electrical or codes then you should be fine.
Old Nov 4, 2023 | 04:03 PM
Acline's Avatar
I have a 1981 Honda Accord and my pos has vauum lines are jacked up, swapped around and it runs like complete **** because of it. and sometimes it won't even crank at all. It leaves me stranded at the wrong times. Th diagram on the hood is a complete mess and it's just not easy to understand. Is there anybody out there that can make it easier on what hoses go where and to what part thy go too? Literally. Like this is ridiculous. Why in the hell would somebody make a vehicle like this.. ?
94exa2
May 20, 2023 12:47 PM
dimfaux
Dec 20, 2019 05:01 AM
TKolodjski
Apr 16, 2014 06:57 AM
95accord327
May 8, 2012 01:36 AM
senor honda
May 22, 2007 11:03 AM
