98 f23a1 slow oil leak gasket set replacement???
Nah, kinda a waste of money.
Those full gasket sets usually don't have all, or half, of the oil seals you really need to repair the more common oil leak areas.
Easily can spend $100 on one of those gasket sets and still not have anywhere near what you need.
Nah, kinda a waste of time to replace random gaskets
Best to clean off the engine, use a green cleaner(simple green/409) and preferably the high pressure soap wand at a coin-op carwash.
With the engine cleaned up. Take the car for a 10mind drive. Pop the hood and look for any fresh oil spots.
Common areas of leakage on the VTEC engines are;
Either replace the seals with Honda seals, or use Victor-Reinz/Mahle seals and gaskets.
- VTEC solenoid to base gasket
- VTEC base to head filter gasket
- VTEC oil pressure switch O-ring(where applicable)
- Valve cover gasket
- Valve cover bolt grommets
- Spark Plug well O-rings
- PCV valve seal
- Oil fill cap gasket
- Distributor O-ring
- Distributor internal seal
- Rear main seal
- Balance shaft seal with retainer
- Oil pump seal
- Oil pressure sensor
B18C5-EH2
32
Nov 29, 2006 08:54 AM
