Suspension & Brakes Theory, alignment, spring rates....
96 JDM ITR Brake Calipers
Old Dec 14, 2019 | 06:56 AM
Linear7's Avatar
Default 96 JDM ITR Brake Calipers
Hey Guys,
I read through the numerous threads on this subject and I'm pretty sure I know the answer I was just hoping someone could confirm my findings, I have 96 JDM ITR knuckles on an EG with 4x100 hubs, I was able to pick up a wilwood dynapro brake kit for an EG pretty cheap, probably should have done a bit more research before buying and I didn't, the caliper mounts all line up but it looks like it needs a spacer to push the caliper out a little so it sits square on the rotor? Can anyone with first hand knowledge confirm this, I can't see any other reason why this wouldn't work and it was talked about in a few threads but I didn't see a clear answer on this combination unless I missed it somewhere. Thanks Everyone
Old Mar 20, 2020 | 12:25 PM
Pepe_Oros's Avatar
Default Re: 96 JDM ITR Brake Calipers
See LaTommyLa YouTubes
Best Regards
Simple SOHC
Suspension & Brakes
May 21, 2010 11:01 PM
egtype-r
Oct 4, 2005 12:11 PM
tangb2023
Jan 21, 2004 09:19 PM
