What is the shaft the VSS bolts onto called?
Old Dec 12, 2019 | 01:21 PM
relentlesstech's Avatar
Icon5 What is the shaft the VSS bolts onto called?
I changed my VSS today, but it was stuck on there so tightly I had to also remove the shaft (with gear at the end) that it bolts to - Long story short, once I got everything back together I started having only half-power, and I got a CEL for P1361, so I am assuming it was something to do with the shaft I pulled out - How can I get everything back to 'normal'?
Old Dec 16, 2019 | 05:50 AM
Default Re: What is the shaft the VSS bolts onto called?
Can be deleted - I figured out that it had nothing to do with the shaft - The puddle I went through also impacted the TDC sensor plug ...
Hovercraft
Transmission & Drivetrain
Jun 2, 2014 06:50 PM
vwtohonda
Honda CR-V & Element
Jul 21, 2012 02:03 PM
Greatness
Jan 15, 2010 05:21 PM
