The engine is D16A8 ZC. I have distributor TD43U, Rywire conversion harness i am confuse to connect conversion harness to original car plug. Its anybody knows the wiring diagram? On the picture is Rywire harness end .
Re: Honda CRX, distributor wire diagram obd0 to obd1
this is what the connector on the D16A8 engine harness should look like:
this is what the connector on the conversion harness should look like: the BLUE/GREEN and BLUE/YELLOW wires noted above are the wires to the CYL sensor on the end of the exhaust camshaft which need to be combined with the wires on the D16A8 connector and connected to the conversion harness
Thanks for your replay.
The first picture is from the connection end of harness wich going to obd1 distributor.
On the second picture( i found in internet) the wiring diagram showing all the pins.
Number 4 and 6 are the cylinder sensors, and the diagram wich you are send me is different , that's way i am confuse because i bean looked both diagrams and can't find the right way.
picture #2 is not correct - here is a picture of the actual distributor connector for the OBD0 MPFI engine
it appears that the jumper has different wire colors - don't worry about that - just make sure that the wires from the D16A8 connector go to the pin locations shown in the picture of the round connector that I posted - use the empty slot as the guide to where they go - the round connector picture I posted is looking at the wire side
here is another picture from Rywire showing wire locations:
Reason: added picture
