Accord Motor Swap need help and advice.
I have a 1993 Accord. I think it has a non-vtec H22 b/c the displacement is 2.2 and it currently has a automatic trans.
I was thinking on swaping in a VTec H22, H23, a S2000, or RSX motor in my 93' Accord. Which engine would be the best choice as in relating to HP, Torque, and quickness? I was thinking on the S2000's motor. Also will any of these motors bolt on to the automatic trans? Are there any turbo kits out there for these motors?
Also anyone know any companies that can beef up my automatic trans with a shift improver kit and higher RPM stall converters?
if your car is stock, it aint no h22. most likely it is f22 auto. the h22/h23 both drop right in. as for the rest of the questions, do some research
OK dude,
as far as engines go, get a H22A from a JDM prelude it fits right in and mounts up to the accord tranny and also it would have less mileage on it try to get a 95 and up .. and far as the tranny convert it to a standard this way the tranny would be able to handle more power and 5speeds are fun...
the S2000 engine would be way too expensive so don't bother with it and the Integra engine also know as RSX ..why bother whay would you want to put a smaller engine ?? does nto make sense. and you won't get much torque either. as far as where to find an engine check the net i think nippon motors have honda engines ...
good luck
good luck
Terrj
Mar 2, 2010 09:49 AM
abeaujuin
Mar 9, 2003 10:12 PM
