Heating problems
Old Dec 8, 2019 | 02:22 PM
Bailey07's Avatar
Default Heating problems
I read as much as i could on this site and other forums, but i have a problem with my 93 civic with a b16a swap. No air moving at all at any speeds. Checked Resistor, blower motor, fuses, relays. Any help would be great thanks
Old Dec 8, 2019 | 02:57 PM
muellersfan's Avatar
Default Re: Heating problems
Are you saying that the the blower motor does NOT work (i.e., no air blows out from the cabin vents)?
Old Dec 8, 2019 | 02:59 PM
Bailey07's Avatar
Blower motor works
Old Dec 8, 2019 | 03:00 PM
Originally Posted by Bailey07
Blower motor works
I'm confused. You said "No air moving at all at any speeds." Please clarify.
Old Dec 8, 2019 | 03:04 PM
Bailey07's Avatar
No air coming out of the vents. At any setting.
Old Dec 8, 2019 | 03:05 PM
Please explain how you know that blower motor works.
Old Dec 8, 2019 | 03:07 PM
Bailey07's Avatar
Applied power to the squirrel cage out side of the car. And it tested good.
Old Dec 8, 2019 | 03:10 PM
But the key question is: Does the blower fail to run when installed in your car?
Old Dec 8, 2019 | 03:12 PM
Bailey07's Avatar
Yes it fails to run in the car. That's what im trying to figure out. With power applied outside of the car its fine. So im trying to figure out why its not getting what it needs in the car.
Old Dec 8, 2019 | 03:36 PM
You need to give details on how you ruled out the fuses, relay, and heater control panel.
KristyC
Aug 31, 2015 02:34 PM
Mr. Fancypants
Jan 18, 2011 11:22 AM
dabflyboy
Jul 3, 2009 03:18 PM
BrenaNickels
Aug 24, 2008 06:10 PM
kyleclapp
Jan 16, 2008 01:44 AM
