D16z6 With P29 pistons, Do i Really need a tune?
Old Dec 8, 2019 | 01:34 PM
BoRiCuA's Avatar
Icon5 D16z6 With P29 pistons, Do i Really need a tune?
Guys If i'm just running p29 pistons on a d16z6 block with I/H/E Do i really need a tune? Compression is ahmmm i think at about 12:1 from my researches, Some do get a tune and some don't, but i would really like to hear from 1st hand experience.
Old Dec 8, 2019 | 06:51 PM
BoRiCuA's Avatar
Default Re: D16z6 With P29 pistons, Do i Really need a tune?
Cmon guys their has to be someone that know, where the gurus at......
Old Dec 9, 2019 | 02:57 AM
NVturbo's Avatar
O.G. triple O.G.
Do you have upgraded fuel pump, injectors, intake manifold, better flowing header, chipped ECU etc? If not.... N O
Old Dec 9, 2019 | 04:00 AM
BoRiCuA's Avatar
As stated above, pistons of course headers/ cold air/ exhaust, no pump, no injectors,still bumps up the compression ratio to 12:1. So stock ecu is fine, is what your saying? Anyone else want to comment. Thanks NVturbo
Old Dec 9, 2019 | 10:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You have changed from 9.2:1 up to over 12:1... OF COURSE YOU NEED A TUNE !!! Your ECU has no idea that you have changed your pistons... or your header, intake or exhaust system.
Old Dec 10, 2019 | 02:26 AM
BoRiCuA's Avatar
Fair enough, can I get away with a chipped ecu? In other words have someone burn me a map that will work?
Old Dec 10, 2019 | 10:34 AM
TheShodan's Avatar
Moderator
NOPE...
Old Dec 10, 2019 | 10:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you mean customizing the fuel and ignition instructions on a DYNO to make sure that these values are appropriate for your engine combination... then yes. If you mean telling some remote chip burner/tuner what parts you have and they send you a one-shot "custom" tune... then NO. That is called a "basemap", not a custom tune.
Essentially, your engine needs to be on a dyno.
spens 91 Ef
21
Feb 26, 2009 06:37 PM
lunch_box_4_life
Oct 17, 2007 09:27 AM
booscivic
Sep 28, 2003 05:34 AM
