Noise at 1500 to 2000 rpm after changing timing belt, water pump, 2 auxiliary belts
Old Dec 6, 2019 | 05:44 PM
Mihajlo Ilic's Avatar
Default Noise at 1500 to 2000 rpm after changing timing belt, water pump, 2 auxiliary belts
I changed the timing belt and water pump, timing belt tensioner, power steering belt, alternator belt. All new parts. The engine is at 196800 km, so it was time to change the belt.
The car is a Honda Civic EJ9 1.4i, hatchback, engine is D14A3.
After this, the car makes a "whining, or almost griding" noise, at the range from 1500 to 2000 rpm, above 2000 rpm it goes away. The mechanic says he can loosen the belt, but it will start whining after 50.000 km.
He says i shouldnt worry, give it some time, it will get quiet over time ?
What do you think, thank you for answers.
Old Dec 6, 2019 | 06:54 PM
chrysler kid's Avatar
Default Re: Noise at 1500 to 2000 rpm after changing timing belt, water pump, 2 auxiliary bel
Mechanic should be able to diagnose the sound himself. If it didnt make the noise before then the mechanic did something wrong and needs to fix it himself
Old Dec 6, 2019 | 08:00 PM
notnilc20's Avatar
With the engine running. Get a long screw driver and put the tip on the body of the ps pump, ac tensioner pulley, and alternator pulley. Put the other end of the screwdriver (the handle) to your ear. You will be able to hear distringuish where the grinding is coming from pretty easily. I had a squeeking/grinding noise also and it was from the ac tensioner pulley bearings going out.
FOR OBVIOUS REASONS. BE VERY CAREFUL NOT TO DROP THE SCREWDRIVER INTO THE BELTS AND BE CAREFUL WHEN HOLDING IT TO YOUR EAR DONT GET IT CAUGHT IN THE BELTS.
Old Dec 7, 2019 | 03:10 PM
Munafo24's Avatar
the whinning is most likely a timing belt that has been tightened too much.
strinm02
May 5, 2014 06:47 AM
pmars
Jul 21, 2012 08:40 PM
Masterdrum
Mar 9, 2009 08:12 AM
danteisme
Jun 23, 2008 12:30 PM
Quiks66
Aug 6, 2004 10:25 AM
