Classic Hondas All Pre-1988 Hondas.
1981 Accord Hatchback cvcc Won't Start
Old Dec 4, 2019 | 07:08 PM
Marshall153's Avatar
Default 1981 Accord Hatchback cvcc Won't Start
So, I had the car running when i bought it (not to bad for $300! ), but the accelerator pump was stuck so it was hard to start. Little squirt of ether and it idled great! But fell flat when hitting the gas. So I took the carb off and cleaned it. Went pretty good so far. I reinstalled it and got all the vacuum lines and solenoids connected. Now it wont start at all even with ether! I checked spark and that's good, orange but still there. As far as valve and ignition timing I'm not sure but it did run before I pulled the carb off. What do I check next? I mean how can it have spark and not start with ether?
Also as a side note, I'm about 87% sure I don't have any vacuum leaks, I did a smoke test with my vape. But I would like to remove and cap as many vacuum lines as possible as emissions are not tested in my area and fewer points of failure would be nice.
Old Dec 8, 2019 | 03:13 PM
Default Re: 1981 Accord Hatchback cvcc Won't Start
Well, turns out my fuel pump quit randomly. Replaced that and now the carb is overflowing through the jets. . .now I get to take the carb apart again! Yay!
Bienval23
Aug 18, 2014 12:14 PM
Zac W.
Aug 13, 2013 03:25 PM
samvilay
Oct 31, 2009 02:46 PM
Frustration!
Mar 13, 2005 12:43 AM
Accord15
Jun 25, 2003 09:54 AM
