No ecu signal to injectors 1,3,4
I have a 93 civic with a d15 and a p28 ecu with a skunk2 manifold as the only mod to the car it is not tuned by the way i cant seem to get 3 of my injectors to fire up i have a new fuel pump ,new injectors , new fuel filters ive check the 3 grounding points VALVE COVER .THERMOSTAT.TRANNY. ALL GOOD AND CLEAN I HAVE CHECKED FOR GROUND GROUND AT ECU PINS A24 AND A23 EVETHING IS GOOD THERE I CONNECT A TEST LIGHT TO THE POSTIVE POST ON MY BATTERY AND CHECHECKED FOR PULSE AT THE ECU SIDE OF THE FUEL INJECTOR WIRES ! WITH THE KEY POSTION ON THE ON (|) POSTION MY ECU WILL LIGHT UP THE TEST LIGHT FROM THE FUEL INJECTOR GROUND WIRES I TURN THE KEY TO THE ON(||) I LOSE THE LIGHT ON MY TEST LIGHT WHEN CRANKING INJECTOR NUMBER 2 IS THE ONLY ONE FIREING ALSO HAVE LOW TO NO SPARK IN 2 CYLINDERS . ONLY WAY I CAN VET THE CAR TO TUEN ON IS JUMPING THE 3 WIRES TO THE INJECTOR 2 PULSE ALTHOUGH IT BACK FIRES ALOT WHEN I PRESS ON THE THROTTLE ANY HELP IS APPRECIATED THANKS .
There are so many possiblities of what could be bad: the crank sensor is in the distributor which provides the signal to the ecu for the injectors to fire, the drivers to the injectors in the ecu could be fried: the main relay is integral in firing the injectors so either start like you have at the injectors and ensure you have constant pwr on one wire and and a pulse ground from the ecu on the other(are different color wires--pwr wires are same color) and work your way back to the ecu and then with a schematic check inputs at ecu-- me I would get a known good distributor, a good working ecu and good working main relay and if nothing changes then I would look for a wiring problem but hey that's me. What is your CEL light doing--does it go out as it should or does it stay on--this is another clue which usually points to ecu or main relay problem if it stays on(then again could be the wiring to them) Has it been running up to now or never ran--check timing
Injectors go from ECU through tower plug C101 onto the individual injector connector on the injector itself. I would check to see that all is well at plug C101 first and then go from there. I say this being you said you are getting signal to one of the 4 injectors, so ECU seems to be operating as well as the distributor is giving signal and spark on all 4 etc.
| Left Tower | |||
| C101 | Tower Harness | 4 pin Grey | |
| C102 | Tower Harness | 10 pin Grey | |
| C103 | Tower Harness | 14 pin Grey | |
| C129 (VX) | Tower Harness | 6 pin Grey | |
| Right Tower | |||
| C124 | Tower Harness | 2 pin Grey | (Power) |
| C125 | Engine Harness | 8 pin Grey | Junction |
| C126 | Tower Harness | 14 pin Grey | |
| C108 | Coolant Temp send unit | ||
| C109 | ECT | 2 pin Grey | |
| C111 | O2 | 4 pin Grey | All but VX |
| C111 | O2 | 8 pin Grey | VX |
| C117 | EVAP | 2 pin Grey | |
| C112 | VSS | 3 pin Grey | |
| C114 | TPS | 3 pin Grey | |
| C115 | IACV | 2 pin Grey | |
| C116 | IAT | 2 pin White | |
| C106 | Distributor | 2 pin Grey | Ign Coil |
| C107 | Distributor | 8 pin Grey | TDC/CKP/CYP |
| C104 | Starter Solenoid | 1 pin Black | |
| C119 | Alternator | 4 pin Green | |
| C127 | Vtec Solenoid | 1 pin Grey | VX/EX/Si |
| C128 | Vtec Pressure | 2 pin Green | VX/EX/Si |
| C130 | EGR Lift Sensor | 3 pin Grey | VX |
| C113 | MAP | 3 pin Grey | CX/VX/EX/Si (CDM EX-V) |
| C201 | MAP | 3 pin Grey | DX/LX (93 Firewall) |
| C404 | ECM | 26 pin Grey | |
| C405 | ECM | 16 pin Grey | |
| C406 | ECM | 22 pin Grey | |
| C120 | Injector 1 (A1) | 2 pin Grey | |
| C121 | Injector 2 (A3) | 2 pin Grey | |
| C122 | Injector 3 (A4) | 2 pin Grey | |
| C123 | Injector 4 (A2) | 2 pin Grey | |
| C118 | Oil Pressure Switch | 1 pin Black | |
| C110 | MT Backup Lght Switch | 2 pin Grey | |
| C110 | AT Lock up Solenoid | 2 pin Grey | |
| Non VX | Label | Wire Colors | Route/Connections |
| C101-1 | ECU Injectors | Red | C404-2 Red ECU A3 to C121-1 Red Injector 2 |
| C101-2 | ECU Injectors | Brn | C404-1 Brn ECU A1 to C120-1 Brn Injector 1 |
| C101-3 | ECU Injectors | Yel | C404-14 Yel ECU A2 to C123-1 Yel Injector 4 |
| C101-4 | ECU Injectors | Lt Blu | C404-3 Lt Blu ECU A5 to C122-1 Lt Blu Injector 3 |
| C102-1 | Ground ECU/G101 | Brn/Blk | C405-9 Brn/Blk ECU B2 to G101 Brn/Blk |
| C102-2 | O2 Sensor | Wht | C406-18 Wht ECU D14 O2 Input to C111-1 Wht O2 Signal |
| C102-3 | Ground ECU/G101 | Blk/Red | C404-26 Blk/Red ECU A26 Ground to G101 Blk/Red |
| C102-4 | ECU CYP/Distributor | Orn | C405-6 Orn ECU CYP B11 to C107-4 Orn Distributor CYP |
| C102-5 | ECU CYP/Distributor | Wht | C405-14 Wht ECU CYP B12 to C107-8 Wht Distributor CYP |
| C102-6 | ECU TDC/Distributor | Orn/Blu | C405-7 Orn/Blu ECU TDC B13 to C107-3 Orn/Blu |
| C102-7 | ECU TDC/Distributor | Wht/Blu | C405-15 Wht/Blu ECU TDC B14 to C107-7 Wht/Blu |
| C102-8 | ECU CKP/Distributor | Blu/Grn | C405-8 Blu/Grn ECU CKP B15 to C107-2 Blu/Grn |
| C102-9 | ECU CKP/Distributor | Blu/Yel | C405-16 Blu/Yel ECU CKP B16 to C107-6 Blu/Yel |
| C102-10 | |||
| C103-1 | |||
| C103-2 | O2 ECU ground | Orn/Blk | C111-4 Orn/Blk O2 Heater to C404-16 Orn/Blk ECU A6 Heater control (ground) |
| C103-3 | Vtec Solenoid | Orn/Wht - Grn/Yel | C404-15 Orn/Wht ECU A4 Vtec Solenoid to C127-1 Grn/Yel Vtec Solenoid |
| C103-4 | MAP signal | Grn/Blu - Grn/Wht | C406-11 Grn/Blu ECU D21 MAP input to C113-2 Grn/Wht MAP |
| C103-5 | MAP ground | Pnk/Wht - Wht | C406-9 Pnk/Wht ECU D17 sensor ground to C113-3 Wht MAP |
| C103-6 | MAP ref volt | Yel/Grn - Yel/Red | C406-10 Yel/Grn ECU D19 reference voltage to C113-1 Yel/Red MAP |
| C103-7 | Vtec Pressure Switch | Orn/Blu - Blu/Blk | C406-14 Orn/Blu ECU D6 Vtec pressure switch input to C128-1 Blu/Blk Vtec pressure switch |
| C103-8 | TPS signal | Pnk/Blk - Red/Blu | C406-6 Pnk/Blk ECU D11 TPS input to C114-2 Red/Blu TPS |
| C103-9 | ECU Sensor Ground | Grn/Wht | C406-22 Grn/Wht ECU D22 Sensor Ground to C111-2 (O2 Signal|), C109-2 (ECT), C116-1 (IAT), C114-1 (TPS), C424-2 (Service Connector) (All Grn/Wht) |
| C103-10 | TPS ref volt | Yel/Wht | C406-21 Yel/Wht ECU D20 TPS reference voltage to C114-3 Yel/Wht TPS |
| C103-11 | Ignition Output Signal | Red/Grn - Yel/Grn | C404-11 Red/Grn ECU A21 and C404-24 Red/Green ECU A22 Ignition Output Signal to C107-1 Yel/Grn Distributor |
| C103-12 | IAT | Red/Yel | C406-8 Red/Yel ECU D15 IAT input to C116-2 Red/Yel IAT |
| C103-13 | ECT | Red/Wht | C406-7 Red/Wht ECU D13 ECT input to C109-1 Red/Wht ECT |
| C103-14 | |||
| C111-1 | O2 Signal | Wht | C102-2 Wht Tower Plug (C102-2 Wht goes to C406-18 ECU D14 O2 Input |
| C111-2 | O2 Signal | Grn - Grn/Wht | O2 Grn to C103-9 Grn/Wht Tower Plug (C103-9 goes to C406-22 ECU D22 sensor Ground) |
| C111-3 | O2 Heater Power | Yel/Blk - Blk | C125-6 Yel/Blk Power Junction to O2 Blk Heater |
| C111-4 | O2 Heater Ground | Grn/Blk | O2 Blk Heater to C103-2 Grn/Blk Tower Plug (C103-2 goes to C404-16 ECU A6 Heater Control) |
| C124-1 | |||
| C124-2 | |||
| C125-1 | Junction (Power) | Yel/Blk | C122-2 Yel/Blk (Injector 3) |
| C125-2 | Junction (Power) | Yel/Blk | C121-2 Yel/Blk (Injector 2) |
| C125-3 | Junction (Power) | Yel/Blk | C120-2 Yel/Blk (Injector 1) |
| C125-4 | Junction (Power) | Yel/Blk | C126-12 Yel/Blk |
| C125-5 | Junction (Power) | Yel/Blk | C115-2 Yel/Blk (IACV) |
| C125-6 | Junction (Power) | Yel/Blk | C111-3 Yel/Blk (HO2 Heater) |
| C125-7 | Junction (Power) | Yel/Blk | C117-1 Yel/Blk (EVAP) |
| C125-8 | Junction (Power) | Yel/Blk | C123-2 Yel/Blk (Injector 4) |
| C126-1 | |||
| C126-2 | |||
| C126-3 | EVAP | Red - Red/Blk (Coupe-Red) | C117-2 Red EVAP Valve to C302-5 Red/Blk (Coupe-Red) Cabin Harness to ECU |
| C126-4 | IACV | Blu/Yel - Grn/White | C115-1 Blu/Yel IACV to C302-2 Grn/Wht Cabin Harness to ECU |
| C126-5 | VSS | Blk/Yel - Yel/Blu | C302-3 Blk/Yel Cabin Harness (From Fuse Box) to C112-2 Yel/Blu VSS |
| C126-6 | VSS | Yel/Blu - Yel/Wht | C302-8 Yel/Blu Cabin Harness (From ECU B10) to C112-3 Yel/Wht VSS |
| C126-7 | |||
| C126-8 | |||
| C126-9 | |||
| C126-10 | |||
| C126-11 | |||
| C126-12 | Yel/Blk | C302-13(Main Relay) - C125-4 Yel/Blk | |
| C126-13 | |||
| C126-14 | |||
| C102-2 | |||
| C102-10 | |||
| C103-1 | |||
| C103-2 | O2 ECU power | Orn/Blk-Yel/Blk | C404-16 Orn/Blk ECU A6 Heater Control (power) to C111-1 Yel/Blk O2 Heater |
| C103-3 | VTEC | Orn/Wht - Grn/Yel | C404-15 Grn/Wht ECU A4 Vtec Solenoid Control to C127-1 Grn/Yel Vtec Solenoid |
| C103-4 | ECU MAP | Grn/Blu - Grn/Wht | C404-11 Grn/Blu ECU D21 to C113-2 Grn/Wht MAP |
| C103-5 | ECU MAP | Pnk/Wht - Wht | C404-9 Pnk/Wht ECU D17 to C113-3 Wht MAP |
| C103-6 | ECU MAP | Yel/Grn - Yel/Red | C404-10 Yel/Grn ECU D19 to C113-1 Yel/Red MAP |
| C103-7 | VTEC | Orn/Blu - Blu/Blk | C404-14 Orn/Blu ECU D6 Vtec Pressure Switch Input to C128-1 Blu/Blk Vtec Pressure Switch |
| C103-8 | ECU TPS input | Pnk/Blk - Red/Blu | C405-6 Pnk/Blk ECU to C114-2 Red/Blu TPS |
| C103-9 | ECU Sensors ground | Grn/Wht | C111-3(O2 Heater2),C130-1(EGR Lift Sensor),C114-1(TPS),C116-1(AIT),C109-2(ECT),C424-2(Service Check Connector) (All Grn/Wht) |
| C103-10 | ECU Refence Voltage | Yel/Wht | C406-21 Yel/Wht ECU to C114-3 Yel/Wht TPS |
| C103-11 | ECU Igntion Output Signal | Red/Grn - Yel/Grn | C404-24 Red/Grn ECU A22 and C404-11 Red/Grn ECU A21 to C107-1 Yel/Grn Distributor ICM |
| C103-12 | ECU IAT Input | Red/Yel | C406-8 Red/Yel ECU to C116-2 Red/Yel IAT |
| C103-13 | ECU ECT Input | Red/Wht | C406-7 Red/Wht ECU to C109-1 Red/Wht ECT |
| C103-14 | |||
| C129-1 | LT EGR | Yel/Wht | C406-21 Yel/Wht Ecu Reference Voltage EGR/TPS D20 to C130-3 Yel/Wht EGR lift sensor |
| C129-2 | LT O2 | Wht/Blu | C406-15 Wht/Blu Ecu O2 Sensor Input D8 to C111-6 Wht/Blu - Red |
| C129-3 | LT O2 | Blu/Yel - Wht | C406-2 Blu/Yel Ecu O2 Heater D3 to C111-4 Wht |
| C129-4 | LT EGR | Wht/Blk | C406-17 Wht/Blk Ecu EGR lift sensor input D12 to C130-2 Wht/Blk Egr lift sensor |
| C129-5 | LT O2 | Blu/Grn - Orn | C406-19 Blu/Grn Ecu O2 Signal Ground D16 to C111-8 Orn - Blk |
| C129-6 | LT O2 | Orn/Blu | C406-18 Orn/Blu Ecu O2 Sensor Input D14 to C111-7 Orn/Blu - Wht |
| C111-1 | O2 Power | yel/Blk - Orn | C103-2 Orn/Blk - Yel/Blk to O2 Heater 1 - C404-16 ECU A6 to O2 |
| C111-2 | O2 Ground | Yel - Blk | G101 - O2 Heater to G101 |
| C111-3 | O2 Ground | Blk - Grn/Wht | C103-9 Grn/Wht O2 Heater - C406-22 ECU (Sensor Ground) |
| C111-4 | O2 Power | Wht | C129-3 Blu/Yel - Wht to O2 Heater 2 - C406-2 ECU to O2 |
| C111-5 | O2 | ||
| C111-6 | O2 Signal | Wht/Blu - Red | C129-2 Wht/Blu to O2 Signal - C406-15 ECU to O2 |
| C111-7 | O2 Signal | Orn/Blu - Wht | C129-6 Orn/Blu to O2 Signal - C406-18 ECU to O2 |
| C111-8 | O2 Signal | Orn - Blk | C129-5 Blu/Grn - Orn to O2 Signal - C406-19 ECU to O2 |
| C124-1 | |||
| C124-2 | |||
| C125-6 | |||
| C126-1 | |||
| C126-2 | |||
| C126-5 | VSS | Blk/Yel - Yel/Blu | C112-2 Yel/Blu VSS to C302-3 Blk/Yel Cabin Harness to Power (Fusebox) |
| C126-6 | VSS | Yel/Wht - Yel/Blu | C112-3 Yel/Wht VSS to C302-8 Yel/Blu Cabin Harness to ECU/CCU/Gauges |
| C126-7 | |||
| C126-8 | |||
| C126-9 | |||
| C126-10 | |||
| C126-11 | |||
| C126-13 | |||
| C126-14 |
HondaCL2.0
Engine Management and Tuning
May 13, 2017 07:37 AM
Legion
Jun 12, 2011 06:36 AM
RJason1111
21
Aug 7, 2009 09:32 AM
