Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 accord ex transmission swap
Old Dec 4, 2019 | 08:37 AM
TerrellD's Avatar
Default 04 accord ex transmission swap
Man.. this is starting to become a pain... long story short my niece was going to give her car away and well she couldn't afford to fix it. Well I decided to get some friends to help swap out her old transmission for a newer one. It's taken some time but I managed to get new transmission in and bolted on. Got car altogether and go to start it... click....click... ok batteries good, took starter to go get tested, starters good so now I'm sure I fudged up the transmission install somewhere if anyone can give me help or guidance please do
Old Dec 4, 2019 | 09:42 AM
shipo's Avatar
Default Re: 04 accord ex transmission swap
If you can hand crank the engine, it is a pretty good bet the transmission isn't the issue.
Old Dec 4, 2019 | 04:05 PM
TerrellD's Avatar
***insert sad face*** cant hand crank the engine, it seems somethings in a bind but all signs point to me having to pull the trans out I was trying to avoid all of that but geez. Is it possible to unbolt the trans and slide it back just to check on everything or does the WHOLE thing have to come back out i.e. axles, suspension
Old Dec 4, 2019 | 04:26 PM
shipo's Avatar
Hmmm, good question, I'm thinking if you prop the engine and trans up separately and undo the mounts you might just get away with pulling them apart an inch or two; no guarantees though.
bogle
Aug 21, 2013 06:30 AM
Jstall7543
Jun 5, 2007 07:54 AM
spiral
Nov 16, 2004 06:57 AM
