B18c /82mm/ Darton Sleeve/ Pro 1 cams/ 6266 turbo/ 1.00a/r Divided hsg. Thoughts?
Hi guys
what do you think about this engine...
b18c darton 82mm
pro 1 cams
6266 1.00 a/r twin scroll
stock head porting or 4 piston ( or someone else)
the car is more drag races and some street(fun) races..
b18c darton 82mm
pro 1 cams
whats your power goal? a 1.8 liter wont see full boost til about 6500-7000rpm with that hotside. For 650-850 hp that should work well. anything less than 650ish could use a smaller exhaust housing. a .82 A/R 6262 can make upward of 650 no prob
My goal is to try to maximize this turbo with water methanol or vp import...The theory told 1.00 a/r on twin scroll is 0.82 on single open...(I am not sure if is true)!
Well it depends on the setup but I've seen the 6266 and 6270 make over 1000whp. Joe over at Locash ran an 8.4 with the 6270.
That's a pretty standard "700 - 800 whp" setup. Make sure you have a good intake manifold along with it. In theory the divided 1.00 is similar to a 0.8x undivided yes. Don't go too big on the turbo manifold runners - that's one of the main reasons people lose a ton of spool. A stainless-steel V-band inlet 0.82 will also work nicely.
The sweet spot of a 62mm setup is 5500 - 9500 rpm.
if I use a 4 piston head or similar you think I will lose a lot on midrange?
Joe runs the Precision stuff and still runs it today, he has run the 6266, 6270 which he set an FIS record with, the 6785 and the 7285. He has run an 8.39 with the 6785 which for AZ is wild when you think these passes are made typically at 90 degree temperatures and about 3500 plus elevation DA's.
The Garrett Custom was on my car and I think it made close to 940whp but like you said the custom wheel would flex and eat the blades. That was the journal bearing Garrett as well, the BB Garrett Custom didn't make as much because the custom wheel was a bit thicker.
Joe might be calling it a wrap, he's getting ready to set up shop at his home in an effort to not burn out, and do this on his own schedule.
That's what I remember, yes...In addition to the BB not making as much power, it really wasn't due to wheel thickness as it was the turbine wheel profile. Let's just say, that's something that's in the works of being changed.
That could be true.
That could be true.
Joe lives up the street from me and his new shop setup is pretty dang nice in comparison to having to drive 35 miles one way to get to work.
Well Joe isn't calling it a wrap, he's just doing something that financially makes sense. Instead of renting multiple shops, building a shop on your property is a pretty smart move.
Make sure you have good headstuds - Speedfactory L19 or ARP CA625+ if plan on pushing the 6266 to make max power (will require a fair amount of boost).
Youll need the thicker version piston pins and a brave rod / rod bolt combo.
If we were talking mid like 4000rpm you wouldnt see a change. But mid with this setup is like 6500 haha.
Setup looks perfect.
You will not loose mid. You will gain mid because a) the engine will be stronger before the spool. 2) You will ride less on the surge line/ be deeper on the compressor map once the turbo starts to spool.
I have cp with upgrade pins and Manley turbo tuff with 625+ bolts...midrange I mean 6000-7500...
Some people have had great success with untouched P72 and PR3 heads, whilst others see great gains with a ported head. I wouldn't imagine the 4Piston head would hurt mid-range too much, generally a lot of R&D goes into CNC heads before they are 'mass produced'. If you wanted to stay on the milder side, something like a 'pocket port' from Port Flow Design might be a good and cheaper alternative.
Thank you good info
Port flow design in Malaysia? I couldn't imagine the shipping hassles on that. I suppose nothing worse than maybe shipping to/from the U.S. *shrug*
I mean honestly if this is mainly a drag car you won't be spending a lot of time at 6000 rpms. During a pass once I launch I'm not going below 8500 the entire time.
Without a strain gauge setup/dog engagment/no lift shift/10k rpm per shift........the Op's setup will likely dip in the 6K-7k territory between certain shifts.
