98 civic Bseries swap
Just trying to see if anybody can help me trying to figure out if I can use the stock integra post mount bracket that on the engine already to bolt up to the D to B mounts...I know the rear T bracket needs to be replaced with a SI T bracket but do I need a SI post mount bracket or is the 1 on the b18b that came attached to the motor already fine to use...Thanks for any advice
A stock B18B has a 3-bolt bracket on it. The Civic Si uses a 2-bolt bracket, and stock mounts will need this bracket to match up. So assuming your bracket is the original one that came with the engine... it will NOT work.
Mr. Dabolina
Jan 18, 2014 08:06 PM
