Timing belt
The issue lies in the D16Y7 head. It's designed for a taller deck so Honda has the cam key 1/2 tooth off compared to the OBD1 heads (D15B7, D16Z6).
You need an adjustable cam gear or to change the cam gear to the D15B7 if I recall. Look up the Y8/B7 minime. It's well documented and they talk about using the opposite cam gear to get the 1/2 tooth variance corrected.
If you are keeping the original B7 tensioner and water pump, you probably will need the 106 tooth B7 belt.
QuarterMileMaster
May 12, 2009 01:53 PM
iNetForce
May 14, 2004 11:10 AM
