USdm 97 prelude H22a euro r swap parts?
Old Nov 29, 2019 | 08:31 PM
B20Ref's Avatar
Default USdm 97 prelude H22a euro r swap parts?
I have a 97 prelude I’m putting a 01 H22a euro r engine and trans into. I need help with what parts I need to make this thing work correctly.
i have bought:
tunable obd1 ecu with euro r map. Xenocron
obd2 to obd1 ecu jumper harness. Rye wire
IACV adapter kit. Rosko racing
what else do I need?
distributer jumper harness? Alternator jumper harness? Fuel rail modification? Egr modification?
i have searched and searched and haven’t found the complete answer?
thank you again for your time.
Old Nov 30, 2019 | 02:19 AM
TimiK's Avatar
10 Year Member
Default Re: USdm 97 prelude H22a euro r swap parts?
Check rosko racing site theres some write up if I remember correctly
Old Dec 2, 2019 | 09:40 PM
Inextricabledrvr's Avatar
First, how do you want your car setup?
Personally, I went with all the USDM components on my EURO R. (Distributor, External coil, USDM oil pump, Alternator, CPS, cam sprockets).It makes it much easier later if any of the parts fail, since they are USDM spec. It seems like you have the adapters needed to run it properly with exception to the fuel rail adapter, throttle cable extender (Rosko should have all these parts still). And please tune the car after swap has been completed. Whether it is Hondata, Chrome, Neptune, etc. You will thank yourself later.
Are you going to run the full Euro R swap with its components?
Or?
Are you going to keep your USDM components and transfer them to your Euro R motor?
Old Dec 5, 2022 | 05:10 PM
TyPeter's Avatar
Hey I need some more information on what all need to be switched over from the usdm to the euro r. Please message me back on here or my number please. Is 541-969-5999
preludeNB
May 20, 2014 07:35 AM
weavertime1
Oct 21, 2007 01:16 PM
weavertime1
Oct 21, 2007 12:35 PM
mlow634
Nov 12, 2006 11:32 AM
TheOnlyChrisB
Jan 17, 2003 03:26 PM
