Swap stalls after warm
Old Nov 29, 2019 | 06:19 AM
Jdilly85's Avatar
Default Swap stalls after warm
I have a 91 civic dx that I swapped a d16z6 in and auto to manual it runs good until it warms up once it warms up it shuts off while driving. It starts right back up will go then shut off again. It has code 41(o2 )sensor code 9 (tdc ) sensor. Code 15 (ignition ) I have a new dizzy now but it’s still doing it. I checked fuel pump. I checked relay. Any ideas any help would be appreciated
Old Dec 8, 2019 | 01:40 PM
~sp33~'s Avatar
EFB055
Default Re: Swap stalls after warm
Does it struggle to idle and die? Or does it just turn off?
Have you done anything to further diagnose those codes besides swapping the dizzy?
Old Dec 9, 2019 | 12:05 PM
Jdilly85's Avatar
No checked the wires still have code 41 02 sensor that’s it. It still shuts off.
Old Dec 9, 2019 | 12:07 PM
Jdilly85's Avatar
Ideals good. Runs good it just shuts off. When at normal temp only while driving.
Old Dec 9, 2019 | 03:37 PM
4drEF's Avatar
Keyboard Humorist
When the engine warms up, the ECU goes into closed loop - meaning it uses feedback from the sensors to manage the engine.
Fix all the codes you are getting.
Old Dec 11, 2019 | 04:29 PM
Jdilly85's Avatar
Swapped dizzy now getting code 9. 15. 41. I changed the icm and the new one went straight to code same three codes. I checked the wires nothing loose or in the wrong place. Any ideas. Thank you.
Old Dec 12, 2019 | 08:14 AM
4drEF's Avatar
Keyboard Humorist
There are a couple ground wires on the thermostat housing. make sure those are intact.
41 should be an easy fix as it is just 2 wires.
Switched 12 Volt (ECU A25)
Heater (ECU A6)
Signal (ECU D14)
Sensor Ground (ECU D22)
You may have the A6 and D22 wires backwards.
Some generic wiring shows both of these wires black, but you can't get them mixed up.
Old Dec 12, 2019 | 08:27 AM
Jdilly85's Avatar
Thank you. I will check
Old Dec 19, 2019 | 08:01 AM
Jdilly85's Avatar
I am getting code 9. Checked with a meter has 380 to all sensors In dizzy. Checked wires to Ecu there are good. I can’t figure it out. It was running good then went to leave and now bogs out when I touch the gas.
I have a 91 Honda Civic dx with d16z6 motor and a6 intake manifold. Used 91dx harness for swap p28 Ecu I did the wires myself. Bought a 0bd0to obd1 jumper harness off line. Did 4 wire 02 sensor did everything needed to run now this is the problem. I can’t figure out this code 9. Now the bog. I don’t know for sure if code will cause bog. Any idea or help I would really appreciate.
Old Dec 20, 2019 | 06:00 AM
Jdilly85's Avatar
No more code. No it still bogs out when touch the gas. I push the clutch in and hit the gas it’s fine but once I put it in gear to go it will bog out
Old Dec 20, 2019 | 12:22 PM
4drEF's Avatar
Keyboard Humorist
Did you reverse the tps wires?
It is part of the DX harness conversion. DX throttle plate rotates the opposite direction than MPFI engines.
Check timing too.
Old Dec 20, 2019 | 12:28 PM
Jdilly85's Avatar
yeah. I have a pr4 Ecu I put it in just to check it and it runs it fine. Runs rich. So I guess my question now is could my p28 be bad. The p28 starts right up it idles normal but if I push the gas it bogs like it’s not getting fuel. It’s like the choke is on after it’s warm.
killafred187
Aug 12, 2011 05:15 PM
~sp33~
13
Jan 14, 2009 12:30 AM
crusto2k3
Dec 1, 2008 02:14 PM
91 POS
Oct 10, 2003 03:17 PM
foesicks
Jun 4, 2003 09:47 AM
