Dim Headlights, Stock Tranny Ground Location?
I did a little bit of troubleshooting, go me!
Main Problem, Dim Headlights.
What I've done so far:
Upgraded to LED Beamtech Headlights (Stock ones no better)
Restored Headlight Lenses
Swapped Relay with another in fuse box
Issues I've Found:
With the car off and headlights on only seeing 11.5V on the headlights, 12V on the battery
With the car running, 14.2V on the headlights, 14.6V on the battery.
Suspects:
Ground Cables - Replaced most of them. There's one under the fuse box going to the transmission I'm weary of. Anybody have a picture of what this one looks like? It's bolted on a hydraulic line bracket I think? Don't know if that's the stock location.
Also, is there a dedicated headlight ground cable?
Might try to get some contact cleaner for the connectors and see if that helps. They don't look terrible.
Might also try leveling the headlights.
Issues I've Found:
Suspects:
JinDIESEL
72
Oct 20, 2004 10:42 AM
