Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Troubleshooting :Annoying whistle (strong vacuum in crankcase) '05 Accord V6
Old Nov 26, 2019 | 03:40 AM
lelroy's Avatar
Default Troubleshooting :Annoying whistle (strong vacuum in crankcase) '05 Accord V6
I have a strange problem nobody has been able to solve. At idle (or higher) the engine whistles. It is not a belt, bearing, etc issue. I have determined it is a whistle due to high vacuum in the crankcase. Here is how I know.
With the engine running and whistling, if I pull the dipstick I hear a whoosh as air rushes into the dipstick tube. Same holds true if I remove the oil cap on the valve cover. If I hold my hand over the oil fill cap, I can feel a good 'suck'.
Before you say "PCV", I have replaced it twice. Once with after market. And just yesterday with an actual Honda PCV valve. No change.
Any ideas why I would have such a high vacuum in the crankcase (+valve cover area)?
Thanks for your thoughts!
-Lawrence
Old Jun 24, 2024 | 01:23 PM
CE1_nobling's Avatar
Icon5 Re: Troubleshooting :Annoying whistle (strong vacuum in crankcase) '05 Accord V6
Did you ever find out the issue ?
My 2005 Accord V6 coupe is doing the exact same thing .
Old Jun 24, 2024 | 01:55 PM
lelroy's Avatar
Default Re: Troubleshooting :Annoying whistle (strong vacuum in crankcase) '05 Accord V6
Old Jun 24, 2024 | 01:56 PM
lelroy's Avatar
Nope, sold it. I suspect it has something to do with the PCV valve in the front left.
Old Jun 25, 2024 | 10:08 AM
I'm thinking the same thing... I replaced the air intake tube and cleaned the throttle body.. and this issue started up.
Oh well , the hunt continues...
Pauls94accord
Jun 30, 2018 02:48 PM
ptschram
Oct 25, 2007 09:56 AM
demadaha
Jul 8, 2007 11:43 AM
hondadriver
Mar 14, 2006 08:03 AM
timthescarred
Jan 15, 2005 03:50 AM
