Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
15 Honda Accord lx catalytic converter
Old Nov 25, 2019 | 05:15 PM
BriV's Avatar
Default 15 Honda Accord lx catalytic converter
Hello,
I am having to replace my bank 1 catalytic converter in my 2015 Honda Accord LX. The part looks accessible but am wondering if anyone has any experience removing the part and if possible any advice in the steps i should follow.
Many thanks
Old Nov 27, 2019 | 08:24 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 15 Honda Accord lx catalytic converter
A four cylinder only has one bank. The lower rear converter usually wouldn't cause any issue unless it was clogged.
To remove the warm up upper converter, start from the bottom of the car. Remove the 3 nuts at the bottom of converter that's connected to the exhaust pipe. Also remove the converter bracket with the two bolts.
From the top of the engine bay, remove the air/fuel ratio sensor.
Remove the 3 bolts holding the cover on top of the converter.
Remove the nuts and bolts holding the converter.
Then remove the whole converter. Gaskets should be replaced on new converter or if reinstalling old converter.
Old Nov 28, 2019 | 01:48 PM
BriV's Avatar
Thank you for the thorough explanation, I will follow your steps once I receive the parts.
Old Dec 3, 2019 | 08:15 PM
BriV's Avatar
Would you happen to know the torque spec for the nuts once I re-tighten them?
Old Dec 4, 2019 | 11:31 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Honda recommends replacing those self-locking nuts. Torque spec. is 54 N.m (5.4 kgf.m, 40 lbf.ft).
barker7
Sep 22, 2011 08:03 AM
JusAccord
Jul 17, 2011 07:36 AM
yomayo
Nov 22, 2006 05:11 PM
