Where to buy specialty fuel fitting?
Hey all, I'm installing new fuel lines but lost one of the fittings that go on the return. It's an inverted flare tube fitting M14 x 1.5, but what makes it different is it's length and that it is threaded a little more than halfway from the thread and is then smooth to the flared end. Have any of you had any luck finding this fitting?
Ask yourself if you want make this car a race car or a daily driver. I your looking to put new fuel connections after market your opening a can of worms. Check performance stores in your area. Even O’Riley carries fuel connections. Personally I’d stick with OEM. You could be risking fire 🔥 even death. Be sure a professional licensed mechanic looks over your work.
None of the stores--O'reilly's, Autozone, Advance Auto, Summit Racing carry any fitting nor preformed line with said fitting; and Honda does not sell this line anymore. I'll probably just have to call around salvage yards. I can form the line, just need the fitting. I'd buy the line just to save a headache but it's discontinued. I did buy various other OEM fuel components, even the rubber fuel hose. Thanks for your concern, though.
hannslebo
Jun 5, 2009 06:13 AM
