User Feedback & Opinions: Comp CT4 Journal Bearing 6262 vs. The Competition
Does anyone know how the comp ct4 jb 6262 turbo compare to a jb precision 6262? Both in T3 exhaust housing .82ar. Comp doesn't seem to be as popular as pte turbos so I didn't see any direct comparisons on the two.
I would probably run a Comp journal over a PTE journal but I would rather run a PTE ball bearing over a Comp ball bearing. If you are interested in only the two companies and only journal I would go with the Comp.
Do you know If these flow as well as the pte turbos? I believe the ct4 is rated at 710hp according to Comp.
Thanks! I guess I really haven't seen many pte jb builds now that I think of it 🤔
I also had a lot of good luck with Garrett Journal Bearing turbos and I've heard that the Borg is very good as well. I would choose these either of these for longevity, for power it would be PTE BB turbos all day especially if it is more geared to race only.
The PTE BB units flow better and spool faster than the Comp stuff. now I've heard the PTE 6262 is good for somewhere around that power as well but again if it is between the two you mentioned I would go with the Comp.
I'm running a cx racing bb gt3582r but currently I'm looking for a little more power. My car put down 521whp @20psi. I believe it has more in it but a few tuners think otherwise.
I ran a Garrett t3t61 with stage 5 wheel and put down 715whp with it.
It was like 850 brand new. My car put down a 9.9 pass with it.
K24 block 10.2 to 1 compression pistons and k20a2 head.
I don't see why my current setup couldn't put down 600whp at maybe 25ish psi and E85.. Thoughts?
-k20a2 head with bc springs and retainers
-cxracing turbo kit with a cxracing GT35r ball bearing turbo.
-deatschwerks 1300cc injectors
-340lph fuel pump
-6an feed and return
-kpro v3
If you look at it my dyno graph it never dropped at any point, it just kept rising in power so based on that I don't see how the turbo is running out of breath. I have a walbro 450lph pump on the way, hoping to get tuned on e85.
K24 block with 10.2 to 1 wiseco pistons
-340lph fuel pump
-kpro v3
-340lph fuel pump
-kpro v3
They aren't going to be helpful, man. They do knock-off GT35Rs, there's no tech to be given.
You can also still get a Borg Warner S360 SX3 from Full-Race with a T4 single scroll housing for $732 ($882 with V-band downpipe connection). This is the non-billet (cast) version but is still rated at 72 lb/min which should still net you 640 whp on E85 on a K-series.
https://www.full-race.com/store/borg...x-83-75-turbo/
Alternatively turn the current CX GT35 up to 25 psi and try. Your dyno graph looks good. Increase the boost in 1-2 psi increments and WHEN you see the turbo stop making additional power STOP. In the interest of Chinese copy cast compressor wheels and bearing assemblies don't make it work harder than it wants too.
With the BW - the more boost you give it, the happier it will be :-)
