B18a1 ls with cable s1 trans
Old Nov 23, 2019 | 10:07 AM
jamesm00's Avatar
Default B18a1 ls with cable s1 trans
I’m having a hard time find motor mount to mount my b18a1 with the s1 trans in my 1994 del sol vtec. What mounts should I use and what would y’all suggest?
Old Nov 23, 2019 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B18a1 ls with cable s1 trans
You will have to buy an aftermarket mount to install a cable transmission into a hydro equipped vehicle. The real question is WHY are you trying to use a cable transmission ? There isn't anything about them that is better than a hydro transmission... parts are harder to find, they are older and likely in rougher shape, and unless you got it for free, the cost of a cable-to-hydro conversion kit and an upper transmission mount will get the cost close to the cost of a hydro trans.
So, I "suggest" you get a hydro transmission and do the swap correctly instead of making it a hack.
turboeagle4g63
Nov 12, 2012 10:09 AM
jnagel12006
Sep 21, 2008 02:14 PM
0ldsk00lef
Feb 4, 2008 05:36 AM
WayFastWhitie
Dec 18, 2004 05:57 PM
biassj
Mar 6, 2004 05:22 AM
