What cams are these? ITR or B16???
Old Nov 21, 2019 | 10:49 PM
BoostInsane's Avatar
Default What cams are these? ITR or B16???
I am building a ls/v turbo and I got a few sets of cams to pick from. I have b16 cams, buddy club spec 3 cams, and what I think are itr cams (was told they were b16 cams). So I was going to use the buddy club cams but then I noticed that both sets of my b16 cams are different from each other. I know one set is for sure a b16 set of cams. But the other set looks like it could be early model itr cams? I researched it and it seems to be but im still unsure as I saw some b16a cams that look similar to itr cams as well. So if they are itr cams then I will be using these instead of the buddy club cams.
Both cams have C and G engraved in the center of the camshafts and there is a slight slant where the distributor goes. If that makes a difference...
I do have upgraded dual valves springs and retainer in the b16 head that I am using already with a set of aem cam gears.
Old Nov 22, 2019 | 10:34 AM
TheShodan's Avatar
Moderator
Default Re: What cams are these? ITR or B16???
Google the B-series image profiles of various OEM B-series camshafts.
eg_6sick
21
Dec 20, 2007 05:56 PM
hyabusa hunter
Nov 17, 2006 04:53 AM
spoolinegsr
Aug 7, 2006 04:37 PM
fed
May 4, 2005 08:57 PM
