2006 Acura TSX - ECT2 wiring diagram needed to fix faulty wiring
Old Nov 20, 2019 | 05:29 PM
sp00led's Avatar
Icon5 2006 Acura TSX - ECT2 wiring diagram needed to fix faulty wiring
I've got a 06' TSX that has an emissions light on the dash display but the ECU code is for the ECT2 sensor. The car has been hit in the front driver side and I highly suspect bad wiring in that harness as I had to fix the headlight wiring. I don't seem to see any obvious ECT2 wiring issues but I think the easiest path forward is to run fresh wires from ECT2 back to the ECU for pinning into harness assuming both go there. Anyone have a wiring diagram for ECT2? My sensor and radiator are new so it feels like a wiring problem.
Thanks in advance!
Old Nov 21, 2019 | 10:49 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: 2006 Acura TSX - ECT2 wiring diagram needed to fix faulty wiring
Check the FAQs/stickies
Old Nov 21, 2019 | 05:04 PM
motoxxxman's Avatar
Old Jan 30, 2020 | 03:36 PM
sp00led's Avatar
Thank you so much!!!
ma91sanchez
Nov 22, 2015 10:11 PM
