2002 Accord Illumination light
Old Nov 20, 2019 | 05:05 PM
TechSavvvvy's Avatar
Icon4 2002 Accord Illumination light
Hi,
I have a 2002 Accord, I replaced the factory radio with a new one, and now the illumination lights (make the screen brighter when the headlights are turned on) for the clock and A/C screen don't work.
The lights for the dashboard and headlights still work. I didn't find any blown fuses, and we didn't connect the illumination wires to the new radio. Does anyone know what the problem could be? Thank you.
Old Nov 22, 2019 | 12:41 PM
Pearlie's Avatar
Default Re: 2002 Accord Illumination light
I've got this problem in my 2003 Accord. I've read that it's a common problem and can be fixed by soldering something in the computer board behind the panel. There are videos on Youtube showing how to do it. I couldn't find a garage that would.
Pearlie
Old Nov 22, 2019 | 05:31 PM
Do you have a link to one of those videos? Thanks
Old Nov 22, 2019 | 08:49 PM
Pearlie's Avatar
Here's one.
If you're successful, would you let us know? After I get my power steering hoses fixed I might try fixing it myself because it drives me crazy not to have those lights.
Old Nov 23, 2019 | 08:06 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Most common problems and electrical circuits/systems for the different generation Accords are not the same.
For the 2002 Accord, the cause may be due to the fuse(s), multiplex control unit (mcu), or wiring. Start with the under-dash fuse(s). In addition to the under-hood fuse box, there is both a driver's side and a passenger's side under-dash fuse box.
Old Nov 23, 2019 | 01:14 PM
I checked all the fuses, nothing is blown, the weird thing is at first the A/C backlight wouldn't work, but now it does, but I didn't do anything to it. I would be happy if the one in the clock would work.
Old Nov 23, 2019 | 01:15 PM
That car is different than mine, that won't work for me.
Old Nov 23, 2019 | 02:57 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Common cause on your generation Accord is the clock illumination bulb needs to be replaced. Honda part number 35505-S84-B02.
Old Nov 24, 2019 | 04:35 PM
But it only stopped after I changed the radio. So I think something else is wrong, is there a way to test the bulb or a way to see if it's getting power?
Old Nov 24, 2019 | 05:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Gently pry the clock bezel assembly out. Unplug connector, test for power on the yellow wire with the ignition switch in the ON or START position.
Old Nov 26, 2019 | 10:45 AM
Is there a black wire or something for the -? Also should it be 12 volts?
Old Nov 27, 2019 | 08:30 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There is a black wire for ground; however, you may want to test for voltage with a different ground point first (other chassis ground) in case there is an issue with the ground wire to rule out the power wire.
Voltage is battery power; so, ~ 12 volts.
Old Nov 30, 2019 | 10:19 AM
I checked the yellow wire, it has power, but it also has power when the headlights are off, so I don't think that's the wire for the illumination light. Do you know what the other wires go to? Thanks for your help.
Old Nov 30, 2019 | 01:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
As I stated previously, common cause on your generation Accord is the clock illumination bulb needs to be replaced.
The yellow wire is power for the clock's backlight. There are other illumination/dimming wires (red/blk and red); however, they are related to the brightness control with the clock's backlight. If your's does not even turn on, it is most likely the bulb.
Old Nov 30, 2019 | 01:51 PM
Ok, I'll get a new bulb and see if that helps.
Old Mar 21, 2020 | 09:01 AM
I know it's been a few months, but I did replace the bulb and that fixed it, thanks everyone!
Heclaboy
Sep 27, 2015 12:03 PM
Protosouls
Oct 20, 2011 04:29 PM
nick25
Aug 14, 2006 12:37 PM
a320
Mar 6, 2005 10:04 AM
joblow
Aug 8, 2002 12:49 AM
