Manual Transmission Oil
Old Nov 20, 2019 | 02:08 PM
UTBMXCruiser's Avatar
Default Manual Transmission Oil
I want to change my tranny oil. God knows how long it's been in there. I see in the older manuals 10w30 or 40 is called for and the newer manuals Honda MTF.
From my 2 stroke dirtbike racing days, I've had good luck running Bel Ray Gear Saver in my trannys. Formulated for a constant mesh transmission.
What are you guys running in your transmissions?
Old Nov 20, 2019 | 02:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Manual Transmission Oil
Just use Acura or Honda brand MTF or go cheap and use engine oil, the manuals actually say what weight engine oil is a compatible replacement if the dealer MTF is not available, I cant remember what oil was recommend on my SOHC but I ended up using engine oil and it works fine.
Old Nov 20, 2019 | 09:30 PM
jdmark1's Avatar
Just put Honda mtf in there
Old Nov 20, 2019 | 10:09 PM
2001GSR4DR's Avatar
Anybody use the GM synchromesh ?
Old Nov 21, 2019 | 03:36 AM
shipo's Avatar
GM Synchromesh is now called ACDelco Synchromesh. If you're going to use it (I do in my TL), make sure you buy the "Friction Modified" flavor, the standard Synchromesh doesn't like Honda transmissions.
Old Nov 21, 2019 | 09:42 AM
thewrai6th's Avatar
No, use Honda MTF. Don't cheap out on your transmission fluid. Engine oil is for when you are stuck in the forest.
Old Nov 21, 2019 | 01:01 PM
shipo's Avatar
ACDelco Synchromesh is not cheaping out on your transmission; it is far superior to Honda MTF which is why so many folks, especially in the 6MT world, rely on the stuff.
Old Nov 21, 2019 | 01:24 PM
BiggieBert's Avatar
Loved
Community Favorite
Also, 92-95 civic’s (yes this is teg sub but) trans were designed to use 10/30...
Old Nov 21, 2019 | 05:02 PM
K20.ek's Avatar
I use the gm synchromesh and works great no complaints here.
Coolcat55
26
Dec 6, 2013 10:02 PM
Hondero_PR
Sep 23, 2012 07:22 PM
9.3.S.I.L.U.D.E.
Transmission & Drivetrain
32
Jul 26, 2009 08:50 PM
Hexar
Oct 13, 2008 12:15 PM
HiChanDC2R
May 6, 2004 06:09 PM
