*ECU trouble. 90 integra(obd0) b18b1 swap, p75 obd2 ecu. HELP
Old Nov 17, 2019 | 06:20 PM
OCEANS8ALASKA's Avatar
Default *ECU trouble. 90 integra(obd0) b18b1 swap, p75 obd2 ecu. HELP
My 90 integra had a b20b that I just killed, so I'm swapping in a b18b1. I got a donor car which came stock with an automatic transmission. I hate automatic in my car's manual so naturally that you see you will not work. I'm trying to figure out if there's a way to go from obd0 to OBD1 (on my car side) and make my ECU which I acquired separately and it's unfortunately OBD2 go to OBD1. Is it possible to use a jumper harness on my car to go from obd0 to OBD1 and connect that to the harness that makes my ECU go from OBD2 to OBD1. I bought the ECU without doing a thorough enough research. Be please help.
Last edited by OCEANS8ALASKA; Nov 17, 2019 at 06:25 PM. Reason: I posted without finishing
Old Nov 17, 2019 | 06:56 PM
Chrisfrom1986's Avatar
Default Re: *ECU trouble. 90 integra(obd0) b18b1 swap, p75 obd2 ecu. HELP
No
Get an obd0 pr4.
Old Nov 17, 2019 | 07:13 PM
Originally Posted by Chrisfrom1986
No
Get an obd0 pr4.
Will it work with the b18b1 correctly? I have that ECU from my b20b
Joeski99Si
Sep 4, 2008 10:18 AM
99civicSiT
Mar 18, 2008 11:55 AM
big-cat
26
Oct 19, 2006 11:14 AM
2.2 teg
Oct 20, 2005 08:21 AM
