ABS Light Comes On Randomly - 94 Accord EX
Old Nov 17, 2019 | 05:04 AM
Fitz Williams's Avatar
10 Year Member
Default ABS Light Comes On Randomly - 94 Accord EX
Car is a 94 Accord EX. The ABS light comes on maybe every other time I start the car. Never first thing in the morning, but next time, probably. I can't find any leaks (had that once and fixed it). I would imagine the problem is electrical, but I don't know where to start looking.
Old Nov 19, 2019 | 07:20 AM
angrysmileyface's Avatar
Default Re: ABS Light Comes On Randomly - 94 Accord EX
Pull the codes. Even if its stored it should leave a code. Typical things that can cause the light to come are low fluid, extended run time, and poor battery voltage. I had an ABS light that wouldnt go away until I reset the module (It was one of those 5-x codes triggered by having crap voltage just once and usually means bad voltage or bad module)
Old Nov 23, 2019 | 03:09 PM
MAD_MIKE's Avatar
MM Gruppe B
*laughs in random ABS/charging issues*
Pull the codes.
Do you have an FSM?
Old Nov 25, 2019 | 06:07 AM
10 Year Member
The ABS code shown is 18. The manual says: "Accumulator gas leakage", or "Changed relief valve set pressure", or "Rear outlet solenoid valve late to close", or "Changed pressure switch set pressure".
coolswimmerjon
Jan 31, 2016 01:05 PM
mherrcat
Oct 9, 2014 01:57 AM
dcarey
Dec 11, 2012 12:18 PM
FurryBalls
Aug 30, 2012 06:21 PM
Agent Daimon
Nov 8, 2010 12:03 PM
