ID1000cc
BDL fuel rail
Walbro 450HP
Full blown billet hanger
Weldon FPR
-8AN feed fuel line
-6AN return fuel line
VP Race Fuel C16
B18C1 GSR
LS crankshaft
Arias Pistons 83mm
9.5:1 static compression
Eagle rods
Darton MID sleeved block
Factory port GSR P72 head Civic
Type-R camshafts
Ferrea valves
Supertech springs and retainers
Borge Warner 362SX-E 62/68 turbo T3/T4. 82ar
BWR Ram horn manifold
BWR 3" down pipe
Ceramic coating on ex manifold, turbo housing, wastegate up pipe & down pipe
Customer 3" exhaust
Custom Garret core intercooler with cast end tanks
Custom 3” intercooler plumbing
Tial 44mm wastegate
Tial BOV
JG Edlebrock intake manifold
BDL throttle body
B16 transmission LS final drive
Sycrotech carbon syncros
Mfactory LSD
Insaneshafts 1000hp axle
First time out at Irwindale Speedway 1/8 drag 11/7/19, got kicked out for going to fast without a cage
R/T: .183
60': 1.735
330: 4.729
1/8: 6.969
MPH: 110.64
Damn.. I get all excited when I see "EG" and especially "Sedan".. Then the hood pops and I see the B-series under the hood.. Total heartbreak.. That being said..
Nice ride! Very well put together. Looking forward to seeing what you do now!
LOL Thanks man. Hard not to build a B-Series. Very proven power plant, cost effective and strong transmission.
Very nice! How did you get over 600whp on 1000cc injectors?
Thanks man. VP C16 race gas, big fuel lines, Walbro 450hp pump and higher base fuel pressure. You can get away with a decent amount of power and safe duty cycle on ID1000 injectors. However once it got to 672whp we where above 90% and had to back out some power.
Next year, after I have some fun on this low boost setup, I’ll throw in some 2000cc and an external pump to turn it up.
Should then easily do 800+whp with good streetablity to cruise back and forth from the track.
Looking really good! Putting the roll cage in changes things, I went from running a few 10.60’s before the cage and then afterwards I struggled to get below a 10.70 until I really cranked up the power. The balance of the car was really off after the cage...... but I felt much safer. I’m finally getting the car balanced back out and now everything is shut down. My best 1/8 mile is still a 6.8 @ 116ph, but it was a 1.86 60ft lol. You are about the same power as myself, only time before you hit a 9 second 1/4 or 6.50 1/8th
Thanks man. Defiantly curious as to how the additional weight will impact the passes. Plan on seeing what I can cut or pull off to help compensate. Then of course turn up some power with bigger fuel setup and more boost. Shouldn’t be to far from going 9.99 or quicker. Need some seat time too.
‘seat time is the key, the more power I make it has become harder to make clean passes down the track. When I first got the car done I ran a 10.60 @ 133mph with a 6.9 1/8 @ 106mph at 16psi. After the roll cage was installed and now at close to 30psi my best has been a 10.30 @ 147mph and 6.8 1/8th @ 116mph. It’s harder to control the power required to make a 9 second pass...... I’ll get there lol
The roll cage adds more weight, sure. It also adds additional chassis stability. Would you say the redistributed weight and added chassis stability is changing suspension geometry enough to throw off those times?
absolutely, felt like I was driving a brick afterwards
Those tires look like a TIGHT fit.. I'd be cautious about running them in any sort of wet conditions too.
looking good!
Thanks! Defiantly a tight fit. Going to roll the fenders and possibly trim the bumper a bit before I take it for a spin. She’ll never see the road if it’s wet either. LOL
I wouldn't THINK about driving mine if the streets were even damp with the Toyo T1Rs, but the Nitto NT05s handle wet streets pretty well, as long as there isn't any standing water.
Awesome car man. Thats the best kind of car to pull up to a meet with if youre looking to make some money. 4 doors and big power is a street sweeper recipe 👌
thanks man. It definitely gets underestimated for being a 4dr. LOL
Originally Posted by DaX
Man those UCA bushings were gone...literally!
yeah completely! Think tire shake took them out when I went to the track. Shouldn’t be a problem now. Eventually I’ll do more spherical bearings on the suspension to stiffen things up.
Awesome setup, OP. On my next setup, it will either be a 4dr Civic or EG hatch. Nowadays, the major downside to a hatch is finding one that is stock and not clapped out. lol
Very cool 4dr. My dad & I also campaigned a 4-door EG here in South Africa (sold as a Honda Ballade here) before switching over to a EG Hatch (foreign import) and turning it into a full drag car.
Where does the S362 SX-E hit full boost ? Are you delaying boost onset purposefully for traction purposes or is it as laggy as the dyno graph makes it appear (Torque peak at 7700rpm) ?
