Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Odyssey J35A7 p2647
Old Nov 14, 2019 | 10:44 PM
Dandi's Avatar
Default Odyssey J35A7 p2647
Hello, I'm new here and I have a problem with my Honda odyssey 2007 J35A7. I bought a car some time ago without an engine and a piece of equipment I was able to complete the car and have been driving it for some time but I have a problem with error p2647. In the car, I personally repaired the engine, i.e. new pistons, heads, etc. The shafts checked everything mechanically works (VTEC), I also replaced a new Vtec valve (rocket arm with sensors), valve clearances checked, new timing and the engine controller also listed according to the chassis number. I suspect that the fault lies on the side of the electrical wiring but I am not sure and I have nowhere to get the wiring diagram for my car (the wiring was bought on ebay seems to be correct but I wanted to check it according to the wiring diagram).
my question is anyone able to help me? gives vin number 5FNRL38497B037485. the engine is without VCM
best regards
Old Jan 2, 2020 | 06:23 AM
PilotMaster's Avatar
Default Re: Odyssey J35A7 p2647
What does code p2647 read out as? Solid or Flashing? Does is seem to be driving fine but just showing a code?
Old Jan 6, 2020 | 09:29 PM
Dandi's Avatar
The code is continuous the car goes to 4500RPM. otherwise ok
Dandi's Avatar
Hest error immediately after starting the car
Old Jan 22, 2020 | 08:47 PM
Dandi's Avatar
Hello, further exploring the topic needs Scheme to exit the pinout from ECM. I have 37820-RGL-A83 and this number also comes out after VIN number. Please help
davisj236
Aug 17, 2015 02:53 PM
nomotor
Aug 26, 2004 08:17 PM
tico_1998
May 6, 2003 02:01 PM
