D16z6 swap
I put a d16z6 in my 91 civic dx. I am using obd0 harnes just ran a wires needed. It starts great a little idle surge when cold. It runs good but it will shut off at random times. It starts right back up. Does anyone have any ideas I checked iac and tps.
You originally said you checked the iac. Did you check the IAT? I've never experienced that causing the engine to cut, but having IAT, TDC, and O2 could point to a wiring issue. If you haven't yet, verify all grounds are clean and tight.
